SIP trunk dont work.-
tate_79
Post by tate_79 »
Hello, im new in that and i dont speak english very well, so i try to explain my problem.-
I have an OXE 10.1 and try to connect one SIP trunk (IPlan), but when i dial from a phone said "congestion".-
I run "tcpdump -ni eth0 udp port 5060" but don't have records, only "supervision timer".-
if run sipextgw -l:
| R E G I S T E R E D S I P E X T E R N A L G A T E W A Y S |
IN SERVICE SIP external gateways list :
1
OUT OF SERVICE SIP external gateways list :
2
sipextgw -s 2
| E X T E R N A L G A T E W A Y Nb 2 A R E A S |
Not found in ARS tables
Not found in ROUTING tables
Leave the settings, thanks!!!
┌─Review/Modify: Prefix Plan───────────────────────────────────────────────────┐
Node Number (reserved) : 101
Instance (reserved) : 1
Number : 7
Prefix Meaning + Professional TG With Overlapping
Prefix Information : 20
Private Route type + False
┌─Review/Modify: Trunk Groups──────────────────────────────────────────────────┐
Trunk Group Id : 20
Trunk Group Type + T2
Trunk Group Name : sip
UTF-8 Trunk Group Name : ---------------------------------------
Number Compatible With : 0
Remote Network : 10
Shared Trunk Group + False
Special Services + Nothing
Node number : 1
Transcom Trunk Group + False
Auto.reserv.by Attendant + False
Overflow trunk group No. : -1
Tone on seizure + False
Private Trunk Group + False
Q931 signal variant + ISDN all countries
SS7 signal variant + No variant
Channel selection type + Quantum
auto.DTMF dialing on outgoing call + YES
T2 Specificity + SIP
genous network for direct RTP + NO
Public Network Category : 31
DDI transcoding + True
Can support UUS in SETUP + True
Associated Ext SIP gateway : -1
Implicit Priority
Activation mode : 0
Priority Level : 0
Preempter + NO
ming calls Restriction categ. : 10
oing calls Restriction categ. : 10
mpt1343 callee number + NO
Overlap dialing + YES
Call diversion in ISDN + NO
┌─Review/Modify: Trunk Group─────────────────────────────────────────────┐
Trunk Group Id : 20
Public Network Ref. : ------
VG for non-existent No. + YES
Entity Number : 0
Supervised by Routing + NO
VPN Cost Limit for Incom.Calls : 0
Immediat Trk Listening For VPN Cal + YES
VPN TS % : 50
Csta Monitored + NO
Max.% of trunks : 0
Ratio analog.to ISDN tax : ------
TS Distribution on Accesses + YES
Quality Profile for Voice on IP + Profile #1
IP compression type + G 711
Use of volume in system + YES
Announcement for Dialtone + NO
Announcement for Ringtone + NO
Reroute Anonymous Calls to Entity + NO
Dialling end to end + NO
DTMF end to end signal. + NO
Trunk group used in DISA + NO
DISA Secret Code : ----
Routing To Executive + NO
Trunk Category Id : 31
Sending of Progress message + YES
Nb of digits unused (ISDN) : 0
B Channel Choice + YES
Channels Reserved By Attend. : 0
Dissuasion For ACD + NO
DTO joining + NO
Enquiry Call On B Channel + NO
Automated Attendant + NO
Calling party Rights category : 0
TS Overflow + YES
Number To Be Added : --------
Charge Calling And ADN Creation + YES
LogicalChannel + 1__15 & 17__31
Use Split Acces + NO
Heterogeneous Remote Network + NO
Barring mode + Not barred
ARS class of service : 31
External Access Server + NO
Mcdu Trk MonitCsta : --------
IE External Forward + None
┌─Review/Modify: SIP Gateway───────────────────────────────────────────────────┐
Subnetwork number : 11
Trunk Group : 20
IP Address : 172.16.6.121
Machin name : oxe
Proxy Port Number : 5060
sipSubscribeMinDuration : 600
sipSubscribeMaxDuration : 86400
Session Timer : 2000
Min Session Timer : 900
Session Timer Method + UPDATE
sipLocalDomainName : lasegunda.com.ar
DNS type + DNS A
First DNS IP Address : 10.5.0.7
Second DNS IP Address : 10.5.0.8
SDP in 18x + True
Cac SIP-SIP + False
d for remote extension + False
Payload type for dtmf : 101
┌─Review/Modify: Proxy─────────────────────────────────────────────────────────┐
Initial timeout : 500
timer T2 : 4000
Dns Timer overflow : 5000
Timer TLS : 30
Recursive search + False
Minimal authentication method + None
Authentication realm : ---------------------------------------
Only authenticated incoming calls + False
Framework Period : 3
Framework Nb Message By Period : 25
Framework Quarantine Period : 1800
TCP when long messages + True
Retransmission number for INVITE : 3
┌─Review/Modify: External Gateways─────────────────────────────────────────────┐
Gateway Name : A Iplan
Remote domain : 190.210.6.162
PCS IP address : -----------------------------------------------
Port number : 5060
Transport type + UDP
Belonging domain : oxe.lasegunda.com.ar
Registration Id : --------------------------------------------------
ation Id in P_Asserted + True
Registration timer : 0
SIP Outbound Proxy : --------------------------------------------------
Supervision timer : 30
Trunk group number : 20
Pool Number : -1
Outgoing realm : --------------------------------------------------
Outgoing username : --------------------------------------------------
Outgoing Password : --------------------
Confirm : --------------------
pported by the distant + True
DNS type + DNS SRV
SDP in 18x + False
authentication method + Digest
only trunk group algo + False
To EMS + False
SRTP + RTP only
Routing Application + False
re inactive/black hole + False
ontact with IP address + False
REL for Outbound Calls + Supported
REL for Incoming Calls + Not Requested
Gateway type + Standard type
. for REGISTER/OPTIONS : 2
d-ID in Calling Number + False
d P-Asserted-ID header + True
on Info to provide via + History Info
Outbound calls only + False
relay on Ext. Call Fwd + Default
Trusted From header + False
Re-invite without SDP + False
Re: SIP trunk dont work.-
Easy the settings are already explained on the documentation. If you followed them then go to the troubleshoot section
Sent from my XPeria Z
tate_79
Post by tate_79 »
I could check and correct the configuration, but i still can't connect with the SIP Trunk.
Now the Ext. Gateway its ok, but when i try to dial in the phone said me "Servicio no Autorizado" (not authorized service).
I send here the entire configuration and trace, thank you for help.-
traza.txt
configuracion SIP Trunk IPLAN.txt
tate_79
Post by tate_79 »
nobody can help me a little?
in your trace i see
transport type tcp(should be udp) ; and port is 5040 (inernal and external gateway that you have conf ports are 5060); max forward =0 !
also try to change in the trunk group for bypassing discremination numberig compatible with -1 and number of digit tosend to cvalue 29 and try again
ReverseFlash
Post by ReverseFlash »
tate_79 wrote: 10 Sep 2013 15:11 Hello, im new in that and i dont speak english very well, so i try to explain my problem.-
if run sipextgw -l:
1
2
sipextgw -s 2
Number : 7
Trunk Group Id : 20
Remote Network : 10
Node number : 1
Implicit Priority
Activation mode : 0
Priority Level : 0
Preempter + NO
Trunk Group Id : 20
Entity Number : 0
VPN TS % : 50
Csta Monitored + NO
Max.% of trunks : 0
DTO joining + NO
TS Overflow + YES
Trunk Group : 20
Machin name : oxe
DNS type + DNS A
SDP in 18x + True
Cac SIP-SIP + False
timer T2 : 4000
Timer TLS : 30
Port number : 5060
Pool Number : -1
DNS type + DNS SRV
SDP in 18x + False
To EMS + False
SRTP + RTP only
Hi BRO!
I was checking, the REMOTE NETWORK its the same SUBNETWORK NUMBER, i saw in REMOTE NET. is 10 in TRK GRP and SIP GTW is 11
i should suggest you change that.
Return to “SIP”
