OmniVista 4760 change IP
Are there any instructions or procedure to change IP address on OmniVista server ?
- Tha Tawa'S
Re: OmniVista 4760 change IP
Yes there are...
-Do Backup
-Stop NMC_ServiceS
-change IP
-delete everything in /4760/data/notify except notify.cfg
-reboot.
-Do Backup
-Stop NMC_ServiceS
-change IP
-reboot.
- frank
From my last time trying this, the 4760 never liked to have a new IP or computer name / domain change.
I had to backup everything , reinstall it all , then restore the backup (data only).
- Tha Tawa'S
I agree the process to change computer name or domain is not the same that described here.
But to change IP adress ONLY, I did it several times successfully.
- frank
Nuviton, try what Tha Tawa's is saying, and let us know !
thanks to all
Update: seems everthing is OK
edwintufis
OmniVista 8770 change IP
How i change the ip in 8770???
Re: OmniVista 8770 change IP
There is a complex cognitive process of decoding symbols in order to construct or derive meaning. It is called reading.
If you use that sacred process to the document "8770 Installation manual" which is properly supplied with 8770 SW you'll find the chapter named "5.7 Modifying the Server FQDN or IP Address".
so wise wordsalex wrote: ↑03 Apr 2017 15:54There is a complex cognitive process of decoding symbols in order to construct or derive meaning. It is called reading.
i haven't R11.2 and 8770 but trying to understand of corse by learning what's new and how to config /install the new features , we never know
- Tha Tawa'S
Same process as 4760 !
