OmniPCX 4400 software for lab use ?
shahed100
Post by shahed100 »
Hi All,
After reading the posts in this forum, I believe it is possible to run the OmniPCX 4400 under VMWare (?)
However, does anyone know if this software (ISO image) is available at a discounted price for lab only use ? (I have looked and it does not seem to be the case, but I ask anyway).
As an example, Cisco offers their CUCM versions from their market place for a few hundred dollars. I was hoping there may be a way to obtain a similar deal for Alcatel images.
Re: OmniPCX 4400 software for lab use ?
If you are a partner you will access to discounts and lab material. If not, then no way.
Return to “Other”
