Log interface link changes
ilugo
Post by ilugo »
I would like to enable logging of interface link changes (port 1/3 changed to link DOWN, etc).
I assume this can be done by changing the log level of the appropriate application / subapplication, but I do not know which one. In previous AOS versions I knew the command would be:
swlog appid INTERFACE level debug1
I know I can see the list of applications using show swlog appid all, but that list is very long and it's not very easy to guess which app/subapp does precisely what. Short of putting them all in debug level until I find the correct one, I was hoping someone here knew...
Re: Log interface link changes
with following dshell-commands you can global activate swlog also for port-up/down:
> dshell
Working: [Kernel]->esmDebugLevel=4
esmDebugLevel = 0x91d0900: value = 4 = 0x4
Working: [Kernel]->exit
You can check it:
> show log swlog timestamp 10/29/2012 00:00
Time Stamp Application Level Log Message
MON OCT 29 12:07:11 2012 INTERFACE info 1/3: link -
MON OCT 29 12:07:17 2012 INTERFACE info 1/3: link +
And for deaktivate of this feature pls use:
> dshell
Working: [Kernel]->esmDebugLevel=3
now I have seen you have a 10k. I'm not sure about the correct command for R7. Please check the cli-guide for it. Maybe there is an other way.
ilugo
Post by ilugo »
Thank you for your response. Indeed I am running a 10k.
For switches running AOS 6.x I know it can be done by raising the loglevel of the INTERFACE app. For the 10k, all I could learn from the cli-guide was how to set the loglevel of a specific app/subapp, and how to get a list of them, but there are so many... e.g. ChassisSupervisor alone has 24 subapps.
I think I'll just try the old fashioned way; elevating the loglevel for everything and plugging a cable, to see which app talks about it.
Return to “OmniSwitch 10k”
