Sinox/Prs
peterg
Sinox/Prs
Post by peterg »
Can anyone help with setting up sonix/prs so i can display an application on my connected iptouch terminal. The phone connects to the sinox and is added ok. I have created a simple app which i deployed using the ipt-prototyper program but all that is displayed on my terminal is the default screen. How do i set up the prs/sinox to tell my terminal to display my created application
Re: Sinox/Prs
If it's not showing nothing then it is because there is something wrong, by default any PRS application becames public, then on OXE you make it private so only authorized users see it on their phone or leave it as public.
Don't know how Synox works, but i believe it should display the application by default. Have you read the documentation of it?
peterg
Re: Sinox/Prs
Post by peterg »
Maybe i am missing something, all we have is an iptouch phone connected to a pc. We have set up sonix/prs and deployed the app. I am a bit confused, if there are say 10 apps configured surely their must be a setting to make so as to display a certain application on the phone.
I am presuming that somewhere in the sonix/prs conf files you need to specify the app to deploy to the phone?
peterg
Re: Sinox/Prs
Post by peterg »
I have added a log showing the PRS showing my app in service...I noticed something about a licence request fail. Do i maybe need a licence to develop an app for iptouch phones???
16/08 15:26:36,477 INFO prs.alarm - PRS version 2.0.0.4.0-134
16/08 15:26:36,477 WARN prs.alarm - 0002 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Presentation Server Starting
16/08 15:26:36,477 INFO prs.monitor.events - The monitor has been started, listening on port 2009, authentication account 'api_support'
16/08 15:26:40,165 [System] WARN prs.alarm - 0008 - AP01 - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Application TEST (AP01) In Service
16/08 15:26:41,133 WARN prs.alarm - 0014 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Licenses request failed - error -42 (Invalid parameter
Feature: XMLIPTOUCH
License path: @localhost
FLEXlm error: -42,113
For further information, refer to the FLEXlm End User Manual,
available at "www.macrovision.com".)
16/08 15:26:41,383 WARN prs.alarm - 0003 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Presentation Server Started
16/08 15:26:41,399 WARN prs.alarm - 0011 - ---- - ----- (0xFFFFFFFFFFFFFFFF,-1) - : Presentation Server configuration loaded
Re: Sinox/Prs
yeah, you might have a hit in your license..
have alcatel check it out, or copy it in here .. without the first 2 lines and 5 last lines
Return to “XML Presentation Server & TAPI Server”
