SIP error "Minor failure in SIP component"
hi at all,
incvisu:
26/03/14 12:49:16 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
26/03/14 12:56:16 000001M|---/--/-/---|=3:5816=Minor failure in SIP component
tmpd/sipalarm:
> 03/26/14 - 12:56:16 Warning alarm
[sip_acceptIncorrectHeader] Header User-Agent is malformed => unknown header
[CIOCom::receiveResponse] Received response is not for this entity
thanks for help
incvisu:
tmpd/sipalarm:
thanks for help
Re: SIP error "Minor failure in SIP component"
Without traces hard to analyze....
As root: tcpdump -s0 -w file port 5060
As mtcl: motortrace 3; traced -d -1 filename -s 1000000 -f 10
After the trace kill traced and Enter motortrace 0
firdaouse1984
Hi Eliott,
I have try to use the taced commad as you mention before:
How can i retrieve the file .Thanks
Wow this post is from 2014... Come on...
How do you get files from OXE?
A clue...FT...
A clue...FT...
cat filename
and save the terminal log into a file
Eliott! You are still around! [emoji41]
Lol, still good to know from you. How are you doing? Your home projects?
Always busy...
Work and private.
Days have not enough hours to finish it all
Work and private.
Lol agree
I know now what married life is like lol and time is much less effective in task doings XD
