how to configure 8082 w/o 8770
ainy
Post by ainy »
can anyone guide me on how to configure My IC 8082 in oxe.
in my system i don't have 8770 license. Also share a document than can be of help.
alex12555
Re: how to configure 8082 w/o 8770
Post by alex12555 »
you can use the 8082 in NOE Mode (like 4068) but you must R10.1.1 Patch 29 or later!
Before this, you can run only this Phone in SIP Mode.
For these two things one does not necessarily need the 8770!
Alex
ainy
Post by ainy »
do you have a doc to refer to know how to configure with out using 8770
Just declare OXE as SIP proxy and in OXE create that extension and register on 8082
oldboy
Post by oldboy »
alex12555 wrote:Hi,
Alex
Alex, you need to be Release 11 for them to run in NOE mode, you also need binary 300 minimum to be able to switch to NOE mode.
ainy
Post by ainy »
My OXE system release is 10.0 and and i need to how to configure My IC without 8770 software. Any useful document?
Like System documentation? There is no a specfic one for "ainy request"
Did you try http://wiki.aappfactory.com ?
There is a wiki page about deploying with a web servers.
Return to “My IC Phone”
