Alcatel to NEC using E1 - QSIG GF
dandy
We manage to get the trunk up between Alcatel and NEC.
Current Situation:
1. NEC can call Alcatel
2. Alcatel cannot call NEC
T3 trace from Alcatel:
| (058889:000002) 1104: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 103 desti: 0 source: 15 cryst: 2 cpl: 3 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 3e
| SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a9 83 83 -> T2 : B channel 3 exclusive
| IE:[1c] FACILITY (l=49)
| [91] Discriminator of supplementary service applications
| [aa] NFE (l=6):
| [80] Source Entity (l=1) End_PTNX
| [82] Destination Entity (l=1) End_PTNX
| [8b] Interpretation APDU (l=1): DISCARD (0)
| [a1] INVOKE (l=16):
| Invoke Ident. : 2ee0 (12000)
| OP: ECMA RO_CALLING_NAME (0)
| [80] Name presentation allowed (l=4) '8000'
| [a1] INVOKE (l=17):
| Invoke Ident. : 2f09 (12041)
| OP: ECMA RO_QSIG_PATH_RETAIN (41)
| [03] Bit string (l=5) 00 86 00 00 00
| IE:[6c] CALLING_NUMBER (l=6) -> 00 81 Num : 8000
| IE:[70] CALLED_NUMBER (l=5) -> 80 Num : 3599
| IE:[7d] HLC (l=2) 91 81
| [95] Locking shift. codeset : 5
| IE:[32] EI_PARTY_CATEGORY (l=1) -> EXTENSION (1)
| (058890:000004) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 3 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 80 3e
| IE:[08] CAUSE (l=2) 81 9c -> [9c] INVALID NUMBER FORMAT
Please advice.
Thank you.
Current Situation:
| SENDING COMPLETE
| [aa] NFE (l=6):
| [a1] INVOKE (l=16):
| [a1] INVOKE (l=17):
Please advice.
Thank you.
Re: Alcatel to NEC using E1 - QSIG GF
and have u seen number of duplicated post lol
i guess 8000 is an alctel extension a
3955 is nec one what kind is did , extension ? at nec side of course
and what about 3955 in alactel translator , network number , 39 routing number , lenghth !?
Another matter:
And the idea of posting this same question 5 times is because....??? Don't spam the forum please or will be taken as that and banned.
dandy
Hi cavagnaro,
First of all sorry for the multiple message. I did sent a private message to Frank explain the issue. When I try to post the subject, I got a SQL error and I try to submit few times without realizing the topic already posted. I will try to capture the error message and send to you.
Sorry for the inconvenience caused.
Thank you.
Thank you.
dandy
Hi haroun,
8000 = alcatel extension
3599 = NEC extension
I set 3599 as routing number :
Routing number = 35
Network number = 10
Trunk group = 1
No of digits = 4
Thank you.
Routing number = 35
Network number = 10
Trunk group = 1
No of digits = 4
Thank you.
It seems here that the NEC is the issue:
The above is the message received by the OXE so it is the NEC not accepting the call
nec says that the format is not good , please post call's trace from a NEC extension to alcatel one (specially from this 3599)
invalid number format (address incomplete).
This cause indicates that the called party cannot be reached because the called party number is not in a valid format or is not complete.
"....the called party number is not in a valid format or is not complete" or not being translated/understood by the remote end?
The message sent by the OXE to the NEC shows clearly that it is sending the correct number (3599)
I would defintely have a closer look at the NEC management
yes tht's it why i ask for a reverse trace to see if 3599 is really exists as 3599"
