When I connect my 4020 phone on the user with number 400142, the phone keyboard doesn't work. If I try with other users in the company, it works well.
Can somone explain me why ?
Thanks you !
Hélianza
[SOLVED] 4020 Phone keyboard doesn't work with on user
Helianza
- tot3nkopf
Re: 4020 Phone keyboard doesn't work with on user
Dial by name and txt msg is set to yes?
Keyboard type is well configured?
keyboard config
minimessage and dial by name yes
User - item Internal Alphanum.Keyboard?
Helianza
The winners are haroun and tot3nkopf. Dial message and mini texte were on No. I set yes, and it works well !
Thanks you very much !
Hélianza
Hélianza
Re: [SOLVED] 4020 Phone keyboard doesn't work with on user
nono the big winner is VAD lol
