I have a problem with my IOM3-XP when the first time I insert that module. The module unprove suddenly, when I checked log id-99 I found this once:
28631 2014/06/25 03:35:00.97 IND MAJOR: CHASSIS #2001 Base Card 3
"Class IO Module : failed, reason: Software detected a failure"
28874 2014/06/25 14:46:46.17 IND MAJOR: CHASSIS #2001 Base Card 3
"Class IO Module : failed, reason: Failure during backdoor bus transfer"
Could you helpme to solve this problem..
According to me, I think the problem maybe TiMOS corrupt or Hardware slot failure.
