We have 2 cabs linked using 100 pair voice cable, the only problem is that when it was installed (some time ago) the engineer didn't test the lines and I guess just assumed they worked. Since then I have had to put some extensions into the second unit and it seems a bit hit and miss which lines work so I want to re-wire the link.
How many wires does the Omni-Office Digital PBX use? And which points does it use as per the image below?
