lanpower configuration lost
walrus
Post by walrus »
I´m having trouble to keep lanpower configuration after a power outage.
Every time the switch is restarted, all the configuration is restored except the lanpower section.
I have to log in the switch and manually re-enter the lanpower start 1 command.
I'm saving the configuration with: write memory and copy working certified commands.
What can be wrong?
Thanks in advance.
Re: lanpower configuration lost
please sent us the following outputs:
show running-directory
show microcode
show hardware info
walrus
Post by walrus »
-> show running-directory
CONFIGURATION STATUS
Running CMM : PRIMARY,
CMM Mode : MONO CMM,
Current CMM Slot : 1,
Running configuration : WORKING,
Certify/Restore Status : CERTIFIED
SYNCHRONIZATION STATUS
Running Configuration : SYNCHRONIZED,
-> show microcode
Package Release Size Description
KFbase.img 6.6.1.679.R01 13465564 Alcatel-Lucent Base Software
KFos.img 6.6.1.679.R01 2146300 Alcatel-Lucent OS
KFeni.img 6.6.1.679.R01 4340262 Alcatel-Lucent NI software
KFsecu.img 6.6.1.679.R01 515249 Alcatel-Lucent Security Management
KFdiag.img 6.6.1.679.R01 2144790 Alcatel-Lucent Diagnostic Software
-> show hardware info
CPU Type : Marvell Feroceon,
Flash Manufacturer : Numonyx, Inc.,
Flash size : 134217728 bytes (128 MB),
RAM Manufacturer : Samsung,
RAM size : 268435456 bytes (256 MB),
Miniboot Version : 6.6.1.636.R01,
Product ID Register : 05
Hardware Revision Register : 30
FPGA Revision Register : 011
devnull
Post by devnull »
I would upgrade to a newer release..
There is a 6.6.1.859
I would upgrade to 6.6.3.552 (needs fpga/miniboot as well..)
and see if the problem persists.. i have 6250 with poe but not with such a old software.
Like devnull has written: please make an update to a newer release and don't forgett fpga/miniboot.
Return to “OmniSwitch 6250”
