I'm develloping an web interface to make calls and personnal directories.
I'm just looking for some CSTA commands (i can't find it on internet and i'm looking for it since 2 days !!!)
On an R9 OXE :
-How to make a call using csta ? using telnet or SSH ? which commands should i send ?
-How to get call timer ?
-How to check if a call is still happening ?
Thanks you
Newbie : some commands CSTA
Re: Newbie : some commands CSTA
discussed before here viewtopic.php?t=5109
csta is a protocol (on port 2555) to dial by a computer application. it doesn't use ssh or telnet.
regards...
regards...
onizukaone
forgot telnet just give me commands plz
Its something like "csta pilot 2a
csta makecall <phone calling> <phone called>"
I've already used it.
As a protocol you need to establish a connection, authenticate, monitor and the do commands...that is not free knowledge as far as I know, haven't found code free around for it.
You have the "what to do" now go and learn it
sorry haven't the commands present in my brain at the moment.
bit the csta commandline client pilot2a description is available in a documentation on businesspartner website.
regards...
regards...
