Impossible to add Windows Deskopt Equipment to Oxe User
jpissot
Post by jpissot »
On OTBE 2.0, I want to install OTC Ct PC to an Oxe User.
In 8770, I ve configured an user with OT rigthts (licence Desktop, and SIP Nomadic). But I can't associate a Windows Desktop Equipment. I can only add :
- MIC Windows
- MIC Android
- MIC BLACKBERRY
-MIC NOkia
Why I can not choose Win Desktop?
Thank you for yours responses
Re: Impossible to add Windows Deskopt Equipment to Oxe User
Windows desktop as mobile? What do you want to do?
tgn
Post by tgn »
the optentouch connection client application for windows does not belong to MIC Windows... also the otct client application does not include connectivity to the 'teamwork functions'. only the otc (opentouch conversation) client has this.
regards...
corwin
Post by corwin »
hi
the association user <=> device in 8770 is developped to give a device its configuration file.
This is the list of user type / device type that follow this dev
user standard/connection:
device mobile (android / iphone / BB / nokia* / windows*) * phase out app
SIP device if user is an OXE sip user (4008EE/4018EE/Thomson)
user multimedia/conversation:
device mobile (android / iphone / BB*) * phase out app.. (the interface need also to add the remote extension...)
SIP device (8082/8002/8012/4008EE/4018EE)
Desktop app (MyIC in OT 1.x / OTC conversation in OT 2.0)
Video Lifesize
Tabled (iPad)
in the list there is no MyIC PC / OTC connection for standard/connection device
this is due to "on the fly SIP configuration" for such user...
MyIC / OTC connection does not need confiugration file to access OT server
only the server/login/passwaord set at client level is needed
and on 8770 configuration, you have to grant the desktop right
with such configuration, you get the "CallControl" feature
to get the Nomadic feature and VOIP on computer,
you must add on Connection user the nomadic right (and the momadic SIP choice..) ,
and within OT configuration, on the synchronized OXE device, you give also some nomadic right...
MyIC PC / OTC connection, will
connect to OT
see that it can swith to VOIP on computer due to nomadic right and then request its SIP confiugration file...
this one is taken in a pool of SIP device configuration (so there is no dedicated sip configuration per user)
that why, it is not in device management, but on OT configuration that you define the list of OXE SIP number that will be used as a pool of SIP device (you need ot put the phone number/ and sip credential)
the next step of MyIC PC / OTC connection start up with Voip on computer, is to fetch such SIP configuration file
OT will grant one of the unused SIP configuration file.
hope it clarify the DM principle of OT solution
Return to “OTMS - OpenTouch Multimedia Services”
