Bonjour à tous
j'ai un probleme avec mon lien E1. j'ai verifier du coté de mon operateur, il me dit que de son coté tout est ok
mais je n'ai pas de tonalité.
quelqu'un peut-il me dire comment verifier que ma config ( de mon lien y compris ma carte E1) est toujours bonne?
que dois-je faire?
merci pour votre aide.
voici l'etat de mon trunk
| T R U N K S T A T E - PRA T Coupler Crystal_nbr = 2 |
| IN SERVICE Coupler Nbr = 6 |
| Access 0 Type : T2 access : ENABLED level2 : ATT_CONNECT2 |
| Trunk Grp 6 6 6 6 6 6 6 6 6 6 6 6 |
| Channel 1 2 3 4 5 6 7 8 9 10 11 12 |
| State hs hs hs hs hs hs hs hs hs hs hs hs |
| Channel 13 14 15 17 18 19 20 21 22 23 24 25 |
| Trunk Grp 6 6 6 6 6 6 |
| Channel 26 27 28 29 30 31 |
| State hs hs hs hs hs hs |
| ALARM COUNTERS |
| NOS | AIS | LOS | FEC/CEC | RAI |
| 1 | 30171 | 876 | 0 | 32766 |
| NOS : no signal | LOS : loss of synchronization |
| AIS : alarm indication signal | FEC/CEC : Frame/Checksum error counter |
| RAI : remote alarm indication | |
Lien E1 ( OXE 4400 R10)
Re: Lien E1 ( OXE 4400 R10)
Please!!! Post in English!!! Help us to help you...why on a 100% English forum you post on another language making it more difficult to get an answer?
got
Hello everyone
I have a problem with my E1 link. I check the side of my operator, he said that his side everything is ok, no alarm on his side
but I have no dial tone. my trunk are all HS
can someone tell me how to check my config (including my link my card E1) is still good?
what should I do?
thank you for your help.
here is the state of my trunk
| ALARM COUNTERS |
what should I do?
| ALARM COUNTERS |
all is clear
nos :no signal 1
ais ALARM INDICATION DE SIGNAL 30171 !
LOS loss of synch (signal) 876 !
RAI Remote side alrm indicator 32766 !!!! >>>> ton signal (tx) n'arrive pas chez l'autre extremité
reverse the cables or the ring and tip of the tx pairs
nos :no signal 1
got
Hello everyone
after work on the side of the operator (reverse cables, loop testing, ...)
My beam is now in service and indicates F (Free)
the problem I have is when I took this line to call, I have no dial tone and no trace on my PBX.
* how should I do to control my setup? to see if my card on my side PRA-T2 is configured properly and that all function
* why I did not tone-hook?
* how to delete trkstat alarms?
thank you for your answers
below how to reach the state of my beam is on and I have no alarm
The role of the CPU is MAIN
Access 0 Type : T2 access : ENABLED level2 : CONNECT2 |
State F F F F F F F F F F F F |
State F F F F F F |
ALARM COUNTERS |
3 | 30258 | 1300 | 0 | 32766 |
State F F F F F F |
ALARM COUNTERS |
hi to clear all alrms
tape increset and choose option 4
it seams that synch is ok as levet2 is connect2
trace for call setup and other t3 C=2 c=6
for dialling tone may you operator doesn't send it as some mobile or sip career
also post you board pra at digital acces level config and the t2 trunk group config
if you set your acces as network mode you should put Bchanal choice at trunk group to yes
got
hi Haroun
Here is the track that I have, can you explain this trace
Can you tell me how do I do (what command) to control my installation?
thank you
(101)oxec> t3
--> Cleaning mtracer...
| 0 | ** | ** | * | ** | * | *** | 165 |
| 1 | ** | ** | * | ** | * | *** | 166 |
| 2 | ** | ** | * | ** | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(054808:000001) MTRACER host (10.x.x.x, oxec), version: R10.0-j1.410-45-c
-x2-c0
(054808:000001) MTRACER num: 016, time: 2014/10/07 15:35:17, loss: 0%
| (054967:000002) 1315: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 31 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 01 4a
| IE:[6c] CALLING_NUMBER (l=2) -> 01 81 Num :
| IE:[7d] HLC (l=2) 91 81
| (055006:000003) 1315: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| IE:[70] CALLED_NUMBER (l=2) -> 81 Num : 0
| (055046:000004) 1315: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 25 desti: 0 source: 15 cryst: 2 cpl: 6 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 01 4a
| IE:[08] CAUSE (l=5) 81 e6 33 30 33 -> [e6] RECOVERY ON TIMER EXPIRY
thank you
(101)oxec> t3
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
mtracer started ...
-x2-c0
no calling number :are you using did or not ; secret identity ?!
called number we see only one digit why ? what type o f trunk seize do you use with overlapping or by block?
bellow normal call using numbering by block
| (069344:000048) 3092: Send_IO1 (link-nbr=5, sapi=0, tei=0) :
| long: 55 desti: 0 source: 15 cryst: 0 cpl: 5 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 56 53
| IE:[18] CHANNEL (l=3) a9 83 88 -> T2 : B channel 8 exclusive
| IE:[6c] CALLING_NUMBER (l=7) -> 00 81 Num : 51009
| IE:[70] CALLED_NUMBER (l=11) -> 80 Num : 7764647
| [a1] Sending complete
| (069345:000050) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 0 cpl: 5 us: 0 term: 0 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : d6 53
| (069382:000051) Concatenated-Physical-Event :
| tei: 0 >>>> message received : ALERT (01) Call ref : d6 53
| (069469:000052) Concatenated-Physical-Event :
| tei: 0 >>>> message received : CONNECT (07) Call ref : d6 53
| (069469:000053) 3092: Send_IO1 (link-nbr=5, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 0 cpl: 5 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CONNECT ACK (0f) Call ref : 56 53
| (069501:000054) 3092: Send_IO1 (link-nbr=5, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 0 cpl: 5 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 56 53
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
| (069501:000055) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 0 cpl: 5 us: 0 term: 0 type a5
| tei: 0 >>>> message received : RELEASE [4d] Call ref : d6 53
| (069501:000056) 3092: Send_IO1 (link-nbr=5, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 56 53
got
hello haroun
actually that's what I do not understand
can you guide me so that I can controlling all my settings?
Can you please guide me step by step to control this?
thank you
thank you
ok you should first post the whole configuration
board config
go to shelf n°2 >>down hierarchy>>board °6 it should be a pra >>>digital acces of this board
post also the trunk group general config and local config of trkgroup
also go down and choose the npd selector for that trkgp.
what's you did range assigned by the operator? .
give also installation numebr if given bythe operator?
also a question the operator has ask you to put your pabx as network or user mode?.
board config
