OLD 2.3.10 on Windows 8
philasphe
Post by philasphe »
Getting the OLD drivers to run on Windows 7 is NOT a problem, everything works well. Now coming to Windows 8, the OLD drivers do not start. Is there a specific parameter that needs to be activated on the Win8 machine. I have the administrator rights.
Godfrey
Re: OLD 2.3.10 on Windows 8
I guess Win7 was a good try and luck. Win8 has a different compilation. I guess won't work, no tricks, no parameters, nothing. Just luck is gone after Win7. Ask for a Win8 compatible version
Return to “Applications”
