INTIP3 board reboot continue
thkim81
Post by thkim81 »
Hi~~
Softmsm configure R11.0.1 in OXE.
INTIP3 softmsm configure and wating for normal status.
configure :
INTIP 3 :
+-Review/Modify: Ethernet Parameters----------------------------------------------------+
| Node Number (reserved) : 6 |
| Shelf Address : 3 |
| Board Address : 6 |
| Shelf - Board Address : 3-6 |
| Interface Type + INTIP3B |
| Board IP Address : 192.168.0.103 |
| IP NetMask : 255.255.255.0 |
| Default Gateway IP Address : 192.168.0.1 |
| IP Quality of service : 0 |
| Cryptographic box address : 192.168.0.103 |
| Board Ethernet Address : 00:80:9f:d2:8b:1a |
| Numb. of sig. channels inter-ACT : 0 |
| IP Domain Number : 0 |
| Gateway H323 name : -------------------------------- |
softmsm :
+-Review/Modify: Addresses to protect---------------------------------------------------+
| Instance (reserved) : 1 |
| IP address : 192.168.0.103 |
| Type + Soft MSM |
INTIP3 board configure :
Board role INT-IP B
MAC address 00809FD28B1A
1. IP address 192.168.0.103
2. Netmask 255.255.255.0
3. Gateway address 192.168.0.1
4. CS role address 192.168.0.105
5. CS redundancy role address 0.0.0.0
6. Crystal number 3 (Manual allocation)
7. IP QoS menu VLAN disabled
BACKUP menu
9. Duplex and speed mode menu auto
10. Download binaries timeout 1200[ms]
11. Passive CS address 0.0.0.0
12. Security and Encryption PROTECT, SoftMSM enabled, PSKg2
13. Telnet server close
14. Archive log files
15. Allow shell commands usage not allowed
0. Exit
but INTIP3 board rebooting continue.
I check the below reset cause log.
Reset: CS DL KO without configured PCS (0 - 0)
this log concern with intip3 board rebooting.
how can I fix INTIP3 board status ?
Split
Re: INTIP3 board reboot continue
Post by Split »
Check BP Sites for new Patch and patchnotes i thought there are some issu with intip3 and softmsm
Is the secured patch installed on the PBX?
Return to “Encryption”
