End of dialing problem
majid2236
Post by majid2236 »
Hi every body
i create a T2(E1 ISDN Access) trunk group for connecting my Alcatel pbx to the Elastix pbx. after that i create a Professional trunk seize for sieze E1 tie line. when i dial 4 digit number PBX system not send digit immediately. i must dial # to send digit immediately or i must wait for 10 second to send digit for destination. what can i do to solve this problem?
Majid
tgn
Re: End of dialing problem
Post by tgn »
just create a "Professional TG With Overlapping" Prefix. Then you can dial Number by Number and each will be sent immediately.
regards...
majid2236
Post by majid2236 »
I know it. front PABX can't understand overlapping. I must design Professional Trunk Seize. do you have any idea for solve this problem?
Use network routing. Why use Trunk group prefix? You can find samples on documentation on Sip trunk integration.
network number , routing number , manager number of digit to be sent (trkgp) , or use descrimination
majid2236
Post by majid2236 »
I connect these two PABX by E1 link. its not sip trunk between them. I don't have sip trunk license. I use discriminator number but it doesn't work.
yes you can? use routing number or network numbber even it 's isdn not sip BTW isdn is older than sip and routing number is based on (T2? QSIG,dass, isdn etc)
juste go to prefix plan
create you for digit extension number as network n° (for routing numebr two first digit if you have more than one destination and give number of digit to be sent) .
give network number any number different of your pbx owner
abcf-2 trunk = your trkgp
other leave as IT
sample
SIP
┌─Review/Modify: Prefix Plan──────────────────────────────────────────────┐
│ Instance (reserved) : 1 │
│ Number : 2000 │
│ Prefix Meaning + Network No. │
│ Network Number : 14 │
│ Node Number/ABC-F Trunk Group : 1801 │
│ Number With Subaddress (ISDN) + NO │
│ Type + SIP device │
│ Identifier : 0 │
SIP
│ Number : 3898 │
│ Prefix Meaning + Routing No. │
│ Number of Digits : 8 │
│ Default X25 ID.pref. + NO │
ABCF-2 NETWORK Internode link
6 is node number
│ Number : 563309 │
│ Network Number : 0 │
│ Node Number/ABC-F Trunk Group : 6 │
│ Type + Station │
│ Identifier : 0 │
NETWORKING VIA E1 ISDN TRUNCK tg=123
│ Number : 57 │
│ Network Number : 10 │
│ Node Number/ABC-F Trunk Group : 123 │
│ Number of Digits : 5 │
For block dialling (but without timeout or "#") use:
- seizure prefix with overlapping
- System - uncheck item "Overlap seizure"
Return to “Trunk Groups”
