ISDN REQUESTED CIRCUIT NOT AVAILABLE
mokhtar ACFE
Post by mokhtar ACFE »
My OXE (Release R8.0) is connected with SELTA PBX via ISDN , all thing is ok the trunk is Free . but when i use a trace t3 C=5 c=3
you find below the result.Can any one helep ?
(1)cs_8> t3 C=5 c=3
--> Cleaning mtracer...
| 0 | ** | ** | 005 | 03 | * | *** | 165 |
| 1 | ** | ** | 005 | 03 | * | *** | 166 |
| 2 | ** | ** | 005 | 03 | * | *** | 167 |
| 3 | | | | | | | |
| 4 | | | | | | | |
| 5 | | | | | | | |
| 6 | | | | | | | |
| 7 | | | | | | | |
Traces Analyser activated
mtracer started ...
(403874:000001) MTRACER host (10.178.17.200, cs_8), version: R8.0.1-g1.503-35-dz -c80s1
(403874:000001) MTRACER num: 011, time: 2014/12/04 08:14:11, loss: 0%
| (403936:000002) 1048: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 48 desti: 0 source: 15 cryst: 5 cpl: 3 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 00 30
| IE:[18] CHANNEL (l=3) a9 83 91 -> T2 : B channel 17 exclusive
| IE:[6c] CALLING_NUMBER (l=11) -> 21 81 Num : 029994711
| IE:[7d] HLC (l=2) 91 81
| IE:[7e] USER_USER (l=1) 04
|___________________________________________________________________________________________________________________________________________________________
| (403939:000003) Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 5 cpl: 3 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 80 30
| IE:[08] CAUSE (l=2) 80 ac -> [ac] REQUESTED CIRCUIT NOT AVAILABLE
Re: ISDN REQUESTED CIRCUIT NOT AVAILABLE
B channel choice configured on your side on on the other PBX?
All B channels used on both side or just a limited number?
mokhtar ACFE
for other pbx (Selta PBX) i congigue B channel , but in OXE how can I configue It?
i use 30 channel .
Only one PBX should have B channel choice --> usually the one that acts as master.
Your PBX send SETUP - and SELTA PBX answer REQUESTED CIRCUIT NOT AVAILABLE.
Ask your provider - what is wrong.
May be SELTA want to have called number in SETUP (try to use block mode dialling).
3 things are wrong
1-calling number -are you using private number ?
2-the called number (destination) missing ,id transcoding is working .
3-protocol is isdn or qsig
btw
Cause No. 44 - requested circuit/channel not available.
This cause is returned when the circuit or channel indicated by the requesting entity cannot be provided by the other side of the interface.
check config number of b chanals and b chanal choice
try to de-active user to user sign
mokhtar ACFE
yes protocole is ISDN
when i test th ISDN trunk , i took directly the trunk by using prefix . not block mode dialling.
afetr your ansewrs . Should I manage config to interconted these PBXs?
You seize ISDN line (we can see SETUP with calling number)
Remote PBX send RELEASE - ask opposite site what is wrong - may be management in remote PBX not support overlap dialing.
Or try with block mode and compare (System - uncheck item "Overlap seizure")
Hi Mokhtar
it's a simple private network call from oxe to selta
firt as you see in the calling number you exetnsion is 4711 and installation number 02999(wich is your pUblic PCM R2 installation ) it's not the cause but may make confusion in clip and call back translator .
simple question the old protocol was qsig and you have change it to isdn so you have recreate the whole trunk grp?, i see calling number but no called one in destination ----> tg prameters number of digits to send is zero or 29 if number compatible with -1 ?
yes try with bloc mode , btw if i try to seize an isdn trunk with overllaping mode i got diconnect with cause no route to destination
Return to “Trunk Groups”
