Analog DISA and IP trunk
vietkhoa
Post by vietkhoa »
Dear all,
I have 2 OXO systems (OXO1 and OXO2) that inter-connected by IP trunks. In OXO1 system, I configure DISA (analog DISA). The DISA is working fine for OXO1, I also want the DISA (on OXO1) can work with the OXO2 system (via IP trunks) transparently for the external caller. Can I manage this?
Thank you
Best regards
Viet Khoa
Re: Analog DISA and IP trunk
Yes, you can. Configure joining between ISDN and analog lines, DISA using substitution, and speed dials or ARS from OXO1 to OXO2 and vice versa, with rights for your substitution extension to dial them.
Regards.
agung4u_DUP
Post by agung4u_DUP »
can both of you tell me how to setting analog DISA? because i try with following from the manual it doesn't success. note my OXO R6.1
thanks
agung4u wrote:can both of you tell me how to setting analog DISA? because i try with following from the manual it doesn't success. note my OXO R6.1
thanks
I guess you need to tick the DISA box on the trunks you need.
agung4u_DUP
in DISA service there is need lisence or not ? or what lisence i need to active DISA?
thanks
agung4u wrote:in DISA service there is need lisence or not ? or what lisence i need to active DISA?
thanks
There's no such license on OXO, but DISA works only on analog trunks on OXO. For ISDN lines you need remote substitution (that is DISA for ISDN lines on OXO ----> kind of different use of terms comparing to OXE).
Regards.
agung4u_DUP
thanks for your information. i will try again.
rgds
agung4u_DUP
can i get TC for DISA because in manual i just found remote substitution not DISA.Thanks
Return to “MAIN”
