I am running successfully my OXE 11.0 as a PSTN-gateway for our Lync 2013 environment without any Audiocodec in-between. I have made an ingeniously number translation system between to two systems so the user have the same number in the OXE and Lync. The Lync user is in this way part of the OXE thru a remote extensions. The remote extensions act a connector to send the call to Lync. For calls from Lync to OXE I use the substitution function to get the call into DISA. The result is brilliant! A receiver of the call using for example a 4039 cannot see in any way that the call comes from a Lync user.
However there is one problem that I cannot solve. When the user likes to use DTMF-tones from the Lync side the tons are filtered by the DISA mechanism, and do not reach the dialed user. If the dialed user sends DTMF-tons in the same call to the Lync user it works. Also when the Lync user dial the special number set up for Dial-tone from the OXE, the Lync user can dial DTMF-tons to the OXE. When routing the call not via DISA substitution, it works fine too.
Can someone tell me why this symptom occurs and if there is a fix for this problem?
Problem with DTMF-tons from Lync-SIP-trunk to DISA substitution!
- tot3nkopf
Re: Problem with DTMF-tons from Lync-SIP-trunk to DISA substitution!
Can you give us the traces from OXE side?
pax
Ok, here is the trace. Note the Lync-call having the number 68801584.
mtracer started ...
(509981:000001) MTRACER host (10.10.10.1, Skogforsk), version: R11.0.1-k1.520-29-e-sv-c0
(509981:000001) MTRACER num: 004, time: 2015/03/24 10:59:29, loss: 0%
(509986:000002) INIT MEVO : uti_inidcom init mevo neqt 1
(509989:000008) INIT MEVO : uti_inidcom init mevo neqt 7
(509993:000014) INIT MEVO : uti_inidcom init mevo neqt 2061
(510012:000021) INIT MEVO : uti_inidcom init mevo neqt 255
(510015:000027) INIT MEVO : uti_inidcom init mevo neqt 2136
(510023:000031) SIP : Global_get_mcdu, unknown hostname
(510023:000032) SIP : Global_get_mcdu, unknown hostname
(510034:000036) INIT MEVO : uti_inidcom init mevo neqt 299
(510037:000042) INIT MEVO : uti_inidcom init mevo neqt 299
(510037:000044) INIT MEVO : uti_inidcom init mevo neqt 2061
(510037:000046) INIT MEVO : uti_inidcom init mevo neqt 13
(510047:000057) INIT MEVO : uti_inidcom init mevo neqt 931
(510063:000069) INIT MEVO : uti_inidcom init mevo neqt 931
(510104:000078) SIP : Global_get_mcdu, unknown hostname
(510104:000079) SIP : Global_get_mcdu, unknown hostname
(510104:000080) SIP : Global_get_mcdu, unknown hostname
(510104:000081) SIP : message INVITE arrive sur le neqt : 1726.
(510104:000082) set_update_allowed : sipAllowUpdate(1726) => before 0 After 0
(510104:000083) INIT MEVO : uti_inidcom init mevo neqt 1726
(510104:000084) Init_reInviteWoSDP(1726) => Not_applicable
(510104:000085) set_typeOfCodecNego(1726) => defaultNego
(510104:000086) set_SipScenario(1726) BEFORE Scenario_undefined AFTER Scenario_undefined
(510104:000087) set_faxProcType(1726) => T38_only
(510104:000088) SIP : ctrl_sip evt : 10752.
(510104:000089) +------------------------------------------------------------+
(510104:000090) | Message received SIP ----> UA (neqt : 1726)
(510104:000091) | INVITE : 481606@10.10.10.1:5060 ; user=phone
(510104:000092) | From : <Patrik> 68801584@skogforsk.se:5060 ; user=phone
(510104:000093) | To : <> 481606@10.10.10.1:5060 ; user=phone
(510104:000094) +------------------------------------------------------------+
(510104:000095) | SDP :
(510104:000096) | @IP:port = 10.10.1.27:49224
(510104:000097) | ALGOS :
(510104:000098) | DTMF : 101
(510104:000099) | PCMA
(510104:000100) | DIRECTION : SEND & RECEIVE
(510104:000101) | cac : false
(510104:000102) | Prack_Required: 0
(510104:000103) | Allow_UPDATE: 0
(510104:000104) | autoAnswer : false
(510104:000105) +------------------------------------------------------------+
(510104:000106) put_algo_G72x.. algo_recu_1=3 algo_recu_2=0
(510104:000107) ctrl_payloads_on_reception_sdp dtmf_payload 101
(510104:000108) ctrl_payloads_on_reception_sdp payloads_recu[0]=0
(510104:000109) ctrl_payloads_on_reception_sdp payloads_recu[1]=255
(510104:000110) is_ems_ext_gw-->ext_gw=-1,Result=0
(510104:000111) ctrl_invite-->EMS-->sip_info_enable =-1 ems=0
(510104:000112) ctrl_invite-->Allow_INFO_received=FALSE
(510104:000113) ctrl_invite-->n_gw_ext=-1
(510104:000114) is_ems_ext_gw-->ext_gw=-1,Result=0
(510104:000115) ctrl_invite-->sip_info_enable=0,dtmf_payload=101
(510104:000116) ctrl_invite prack_required = 0 wc = 0
(510104:000117) SIP : ctrl_sip content_type : 1 black_hole 0 inactive_direction 0
(510104:000118) SIP : ctrl_sip !!!!! local.stop_rtp = FALSE !!!!
(510104:000119) type_of_url : 3
(510104:000120) URL_type_local_num
(510104:000121) status trad=9 subnetId=9
(510104:000122) appel_poste_sip_local = NON
(510104:000123) SIP sui_arr_sip : ptdemi->findemi.Ureso.no_tmp_etab = 0
(510104:000124) SIP sui_arr_sip-->treatment ext-->indirect=4
(510104:000125) build_calling_from_sip-->n_gw_ext=-1
(510104:000126) build_calling_from_sip: unknown host
(510104:000127) SIP : Global_get_mcdu, unknown hostname
(510104:000128) get_extension_nulog-->pris_dep=1
(510104:000129) SIP sui_arr_sip :called_entity=1000
(510104:000130) sui_arr_sip_bis
(510104:000131) ### sui_arr_sip_bis
(510104:000132) SIP : ptdemi->init_party_nr 00: 101
(510104:000133) SIP :ptdemi->explmevo : 0
(510104:000134) discri_sip-->nulog=-1
(510104:000135) sui_arr_sip_bis No error_code
(510104:000136) MEVO : init_feature_2_id option1 1 ,2 1, rvext = 1
(510104:000137) CCBS_CCNR false
(510104:000138) dtmf_auto = on ET_U1
(510104:000139) SIP_my_data() : sipAllowUpdate(0)
(510104:000140) SIP: ALLOWUPDATE: csu(1726) set_feature_allow_update 0 -> 1
(510104:000141) find_a_gateway neqt=1726 called_entity=1000
(510104:000142) find_a_gateway nulo_final 65535
(510104:000143) sui_arr_sip: eqt_copain=-3
(510104:000144) sendipns :envoi de ei_sending_complete dans le setup
(510104:000145) SIP BEARER CAPABILITY 0
(510104:000146) SIP SIP_remp_channel etat_t2 = 1
(510104:000147) SIP_remp_calling_name: 1816144 lg=0
(510104:000148) SIP : url_to_text_display : avant
atrik
(510104:000149) SIP : url_to_text_display : apres
atrik
(510104:000150) SIP_remp_calling_name: 1816144 lg=12
(510104:000151) SIP : remp_specific_classmarks-->SIP_remp_specific_classmarks
(510104:000152) SIP_remp_specific_classmarks-->etat_t2=1
(510104:000153) SIP_remp_specific_classmarks cnip_received
(510104:000154) SIP : ptdemi->init_party_nr 2 : 101
(510104:000155) SIP : remp_charging_info explmevo=0 typconv=1 pris_dep=1.
(510104:000156) SIP : remp_charging_from_voice_mail_info pris_dep.
(510104:000157) SIP : remp_charging_from_voice_mail_info reptrad.Type.Com =6.
(510104:000158) SIP : remp_charging_from_voice_mail_info reptrad.Type.Com <> Tsl_CH_Data.
(510104:000159) SIP : remp_charging_info trunk.
(510104:000160) SIP : SIP_remp_calling_number-->extGw=-1
(510104:000161) SIP : SIP_remp_calling_number octet3=0x0
(510104:000162) remplissage_sip_to_ipns don't send EI_ENCRYPTION case 1
(510104:000163) SIP_remp_ip_payloads shift 1 jeu_courant 128
(510104:000164) SIP : remp_rtp_info : Port RTP = 49224
(510104:000165) SIP : remp_rtp_info : IP 0 = 10
(510104:000166) SIP : remp_rtp_info : IP 1 = 10
(510104:000167) SIP : remp_rtp_info : IP 2 = 1
(510104:000168) SIP : remp_rtp_info : IP 3 = 27
(510104:000169) SIP : remp_rtp_info : Port RTCP_SR = 49225
(510104:000170) SIP : remp_rtp_info : IP 0 = 10
(510104:000171) SIP : remp_rtp_info : IP 1 = 10
(510104:000172) SIP : remp_rtp_info : IP 2 = 1
(510104:000173) SIP : remp_rtp_info : IP 3 = 27
(510104:000174) SIP : remp_rtp_info : Port RTCP_RR = 49225
(510104:000175) SIP : remp_rtp_info : IP 0 = 10
(510104:000176) SIP : remp_rtp_info : IP 1 = 10
(510104:000177) SIP : remp_rtp_info : IP 2 = 1
(510104:000178) SIP : remp_rtp_info : IP 3 = 27
(510104:000179) SIP : remp_rtp_info : Port FAX = 0
(510104:000180) SIP : remp_rtp_info : FAX 0 = 0
(510104:000181) SIP : remp_rtp_info : FAX 1 = 0
(510104:000182) SIP : remp_rtp_info : FAX 2 = 0
(510104:000183) SIP : remp_rtp_info : FAX 3 = 0
(510104:000184) set_update_allowed : sipAllowUpdate(1790) => before 0 After 0
(510104:000185) INIT MEVO : uti_inidcom init mevo neqt 1790
(510104:000186) Init_reInviteWoSDP(1790) => Not_applicable
(510104:000187) set_typeOfCodecNego(1790) => defaultNego
(510104:000188) set_SipScenario(1790) BEFORE Scenario_undefined AFTER Scenario_undefined
(510104:000189) set_faxProcType(1790) => T38_only
(510104:000190) chained_transit_call 0
(510104:000191) analyse_ei_ipns no call to Find_Sip_Notif nummcdu -1 !!
(510104:000192) ctrl_party_cat ptdemi->abonne_reseau = 0
(510104:000193) SIP : recupere_compression_type(1790) : DEFAULT_COMPRESSION G711
(510104:000194) sip: value for ipdata [1] neqt=[1790]
(510104:000195) sip: !!!it is sip eqt and ip_data_received set for eqt 1790
(510104:000196) sip: value for ipdata 1
(510104:000197) ctrl_ei_rtp_info otuc_encrypt=0 SameAdresse=0
(510104:000198) can_sip_trunk_be_secured(1790)=0
(510104:000199) Getpttrav-->false
(510104:000200) put_rtp_info end 1790 local.wc=0 distant.wc=0
(510104:000201) SIP : copy_rtp_data_for_sip_use : local or distant : 1 sens : 1
(510104:000202) SIP : copy_rtp_data_for_sip_use : carte_fille_lio=3
(510104:000203) ctrl_feature_ident is_remote_update_supported before = 1
(510104:000204) ctrl_feature_ident is_remote_scenario_supported before = 1
(510104:000205) ctrl_feature_ident is_remote_update_supported after = 0
(510104:000206) ctrl_feature_ident is_remote_scenario_supported after = 1
(510104:000207) ctrl_feature_ident is_remote_update_supported before = 0
(510104:000208) ctrl_feature_ident is_remote_scenario_supported before = 1
(510104:000209) ctrl_feature_ident is_remote_update_supported after = 0
(510104:000210) ctrl_feature_ident is_remote_scenario_supported after = 1
(510104:000211) ctrl_feature_ident is_remote_update_supported before = 0
(510104:000212) ctrl_feature_ident is_remote_scenario_supported before = 1
(510104:000213) ctrl_feature_ident is_remote_update_supported after = 0
(510104:000214) ctrl_feature_ident is_remote_scenario_supported after = 1
(510104:000215) ctrl_feature_ident is_remote_update_supported before = 0
(510104:000216) ctrl_feature_ident is_remote_scenario_supported before = 1
(510104:000217) ctrl_feature_ident is_remote_update_supported after = 0
(510104:000218) ctrl_feature_ident is_remote_scenario_supported after = 1
(510104:000219) sipABCFLocalCall is TRUE
(510104:000220) goodConfigForScenario true
(510104:000221) can_sip_trunk_be_secured(1790)=0
(510104:000222) ctrl_feature_ident can_sip_trunk_be_secured(1790)=0
(510104:000223) sipABCFLocalCall is TRUE
(510104:000224) goodConfigForScenario true
(510104:000225) can_sip_trunk_be_secured(1790)=0
(510104:000226) ctrl_feature_ident can_sip_trunk_be_secured(1790)=0
(510104:000227) arr_q931 neqt 1790 neqt sip 1726 voip_en_fast_start 1
(510104:000228) find_a_gateway neqt=1726 called_entity=1000
(510104:000229) find_a_gateway nulo_final 65535
(510104:000230) sui_arr_q931 : ReINVITEWOSDP false + TypeofCodec - Default
(510104:000231) set_reInviteWoSDP_False(1790) => reInviteWoSDP_False
(510104:000232) set_typeOfCodecNego(1790) => defaultNego
(510104:000233) set_faxProcType(1790) => T38_only
(510104:000234) SIP mise_a_jour_des_canaux ind=0 neqt=1790 allocation=1
(510104:000235) SIP mise_a_jour_des_canaux state=0
(510104:000236) SIP : besoin_et_echec_alloc_comp -> faisceau SIP ou ABCIP
(510104:000237) SIP : besoin_et_echec_alloc_comp -> arrivee
(510104:000238) get_neqt_numcomp numcomp 4 8 1 6 10 6 0 0 0 0 0 0 0
(510104:000239) RtpDirectAllocComp-->neqt_de=-1,rtp_direct_distant.wc=0
(510104:000240) get_neqt_numcomp numcomp 4 8 1 6 10 6 0 0 0 0 0 0 0
(510104:000241) get_neqt_numcomp numcomp 4 8 1 6 10 6 0 0 0 0 0 0 0
(510104:000242) put_rtp_info end 1790 local.wc=0 distant.wc=0
(510104:000243) put_rtp_info end 1790 local.wc=0 distant.wc=0
(510104:000244) !!!!!!!! send_evt EVT_UPDATE_RTP -> 1790
(510104:000245) SIP : isMulticodecNetwork 0
(510104:000246) SIP mise_a_jour_des_canaux ind=0 neqt=1790 allocation=1
(510104:000247) SIP mise_a_jour_des_canaux state=3
(510104:000248) find_a_gateway neqt=1726 called_entity=1000
(510104:000249) find_a_gateway nulo_final 65535
(510104:000250) sip_behind_ice-->neqt=1790,Result=0
(510104:000251) SIP SIP_remp_channel etat_t2 = 6
(510104:000252) make_trunk_barring-->faisceau sip en face-->AUTORISE
(510104:000253) trans remote extension disa used on SIP
(510104:000254) get_neqt_numcomp numcomp 4 8 8 6 10 6 0 0 0 0 0 0 0
(510104:000255) SIP : isMulticodecNetwork 0
(510104:000257) Marhaban bikom dans le monde SIP : dtmf_payload(1790)= 101
(510104:000258) is_ems_ext_gw-->neqt=1790,Result=0
(510104:000259) send_cpl_connect_rtp_direct-->dtmf_direction=0
(510104:000260) get_cfl_and_faxtype neqt(1790)
(510104:000261) get_cfl_and_faxtype: SIP ou ABCIP cfl 0x60 faxtype 0
(510104:000266) MEVO : sauve_categorie_mevo monneqt 1790 neqt 1790
(510104:000267) MEVO : option1 1 ,2 1
(510104:000268) MEVO : sauve_categorie_mevo monneqt 1790 neqt 1790
(510104:000269) MEVO : option1 1 ,2 1
(510104:000270) is_ems_ext_gw-->Result=0
(510104:000271) is_ems_ext_gw-->neqt=1790,Result=0
(510104:000272) ptdemi->nummcdu -1
(510104:000273) SIP SIP_remp_channel etat_t2 = 7
(510104:000274) SIP SIP_remp_channel Pas de chance
(510104:000275) remplissage don't send EI_ENCRYPTION case 2
(510104:000276) EI_IP_PAYLOADS HardwareLess 0 ptdemi->info.hinfo 255
(510104:000277) SIP : copy_rtp_data_for_sip_use : local or distant : 1 sens : 0
(510104:000278) SIP : copy_rtp_data_for_sip_use : carte_fille_lio=3
(510104:000279) Enter remp_ip_payloads-->nummcdu=-1
(510104:000280) No copy_rtp_data_for_transit_use 1790
(510104:000281) Il_y_a_de_l_ABC_IP 6 result=0
(510104:000282) Il_y_a_du_SIP 1 neqt 1790 remote_device 0
(510104:000283) Il_y_a_du_SIP 3 result=1
(510104:000284) Il_y_a_du_SIP 1 neqt 1790 remote_device 0
(510104:000285) Il_y_a_du_SIP 3 result=1
(510104:000286) EI_RTP_INFO 5: payload=101
(510104:000287) sip_behind_rex dcom -- start
(510104:000288) get_sip_dcom_behind_rex : nummcdu = -1
(510104:000289) isSDPTransitCase(1790)(pt_sip=1790) nummcdu=-1
(510104:000290) SIP : isMulticodecNetwork 0
(510104:000292) sip_gw_ext_can_support_sip_info-->neqt_copain=1726,called_entity=1000
(510104:000293) is_ems_ext_gw-->ext_gw=1000,Result=0
(510104:000294) sip_gw_ext_can_support_sip_info :Result=0
(510104:000295) sip_ems_with_rfc2833-->disa_for_remote_ext=1
(510104:000296) sip_ems_with_rfc2833-->neqt_copain=1726,called_entity=1000
(510104:000297) sip_ems_with_rfc2833-->dtmf_payload=101,dtmf_direction=0
(510104:000298) is_ems_ext_gw-->ext_gw=1000,Result=0
(510104:000299) sip_ems_with_rfc2833-->Result=0
(510104:000300) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510104:000301) rcl_for_overdialling-->sip with rfc2833-->No need RCL
(510104:000302) rcl_for_overdialling-->ptdemi->neqt_it=1790
(510104:000305) SIP SIP_remp_channel etat_t2 = 7
(510104:000306) SIP SIP_remp_channel Pas de chance
(510104:000307) remplissage don't send EI_ENCRYPTION case 2
(510104:000308) EI_IP_PAYLOADS HardwareLess 0 ptdemi->info.hinfo 255
(510104:000309) SIP : copy_rtp_data_for_sip_use : local or distant : 1 sens : 0
(510104:000310) SIP : copy_rtp_data_for_sip_use : carte_fille_lio=3
(510104:000311) Enter remp_ip_payloads-->nummcdu=-1
(510104:000312) No copy_rtp_data_for_transit_use 1790
(510104:000313) Il_y_a_de_l_ABC_IP 6 result=0
(510104:000314) Il_y_a_du_SIP 1 neqt 1790 remote_device 0
(510104:000315) Il_y_a_du_SIP 3 result=1
(510104:000316) Il_y_a_du_SIP 1 neqt 1790 remote_device 0
(510104:000317) Il_y_a_du_SIP 3 result=1
(510104:000318) EI_RTP_INFO 5: payload=101
(510104:000319) sip_behind_rex dcom -- start
(510104:000320) get_sip_dcom_behind_rex : nummcdu = -1
(510104:000321) isSDPTransitCase(1790)(pt_sip=1790) nummcdu=-1
(510104:000322) chgt_local_rtp_info ptdemi->info.hinfo=0 ptdemi->neqt=1790
(510104:000323) chgt_local_rtp_info local.wc=0 distant.wc=0 before update
(510104:000324) SIP :sip_chgt_local_rtp_info :we are not sip trunk
(510104:000325) sip_chgt_local_rtp_info : (1726)->pris_transit = 0
(510104:000326) sip_chgt_local_rtp_info : (1790)->donnee_recue = 1
(510104:000327) sip_chgt_local_rtp_info : EVT_UPDATE_RTP -> 1726
(510104:000328) !!!!!!!! send_evt EVT_UPDATE_RTP -> 1726
(510104:000329) chgt_local_rtp_info end local.wc=0 distant.wc=0
(510104:000330) chgt_local_rtp_info ptdemi->info.hinfo=0 ptdemi->neqt=1726
(510104:000331) chgt_local_rtp_info local.wc=0 distant.wc=0 before update
(510104:000332) chgt_local_rtp_info end local.wc=0 distant.wc=0
(510104:000333) ctrl_party_cat ptdemi->abonne_reseau = 0
(510104:000334) SIP_ctrl_ip_payloads ptdemi->payloads_recu[0]=0
(510104:000335) ctrl_ei_rtp_info otuc_encrypt=0 SameAdresse=0
(510104:000336) can_sip_trunk_be_secured(1726)=0
(510104:000337) put_rtp_info end 1726 local.wc=0 distant.wc=0
(510104:000338) SIP : copy_rtp_data_for_sip_use : local or distant : 1 sens : 1
(510104:000339) SIP : copy_rtp_data_for_sip_use : carte_fille_lio=0
(510104:000340) remp_history_info_to_sip-->Result=0
(510104:000341) SIP : ALLOWUDPATE : send_sip_informational : mess.AU <= CSU(1726) 1
(510104:000342) send_sip_informational gateway_sip.SDP_in_180 1
(510104:000343) find_a_gateway neqt=1726 called_entity=1000
(510104:000344) find_a_gateway nulo_final 65535
(510104:000345) is_ems_ext_gw-->ext_gw=1000,Result=0
(510104:000346) remp_SDP_one_algo direction 0
(510104:000347) sdp_transparency_hardwareless neqt (1726) hinfo (0)
(510104:000348) sdp_transparency_hardwareless index (-1)
(510104:000349) send_sip_informational -> remp_SDP_one_algo
(510104:000350) send_sip_informational -> CFL 0
(510104:000351) SIP_ISDN_Transit_case ptdemi(1726)
(510104:000352) SIP_ISDN_Transit_case : SIP ABCF eqt(1726)
(510104:000353) SIP : [send_to_motor] ipcSend resultat : 0 sur eqt : 1726
(510104:000354) SIP : [ipc_send] envoi du message : 10764.
(510104:000355) +------------------------------------------------------------+
(510104:000356) | Message sent UA (neqt : 1726-0) ----> SIP
(510104:000357) | Informational 180
(510104:000358) |RELATIVE REQUEST : INVITE
(510104:000359) | Allow_UPDATE: 1
(510104:000360) +------------------------------------------------------------+
(510104:000361) | SDP :
(510104:000362) | @IP:port = 10.20.10.1:32248
(510104:000363) | ALGOS :
(510104:000364) | PCMA
(510104:000365) | DTMF : 101
(510104:000366) | DIRECTION : SEND & RECEIVE
(510104:000367) +------------------------------------------------------------+
(510104:000368) ctrl_party_cat ptdemi->abonne_reseau = 0
(510104:000369) SIP_ctrl_ip_payloads ptdemi->payloads_recu[0]=0
(510104:000370) ctrl_ei_rtp_info otuc_encrypt=0 SameAdresse=1
(510104:000371) can_sip_trunk_be_secured(1726)=0
(510104:000372) put_rtp_info end 1726 local.wc=0 distant.wc=0
(510104:000373) SIP : copy_rtp_data_for_sip_use : local or distant : 1 sens : 1
(510104:000374) SIP : copy_rtp_data_for_sip_use : carte_fille_lio=3
(510104:000375) recoit_connect mcdu_reseau=0
(510104:000376) recoit_connect octet3=0x1 octet3a=0x81
(510104:000377) build_connected_to_sip num=0
(510104:000378) build_connected_to_sip COLR=0
(510104:000379) recoit_connect check_for_rtp_change
(510104:000380) SIP :check_new_rtp_infos_received no change same_algo = 1 /same_address = 1 result=0
(510104:000381) put_rtp_info end 1726 local.wc=0 distant.wc=0
(510104:000382) send_sip_successful PEM reset
(510104:000383) send_sip_successful->called_entity=1000
(510104:000384) is_ems_ext_gw-->ext_gw=1000,Result=0
(510104:000385) send_sip_successful->donnee_recue=1
(510104:000386) send_sip_successful->ptdemi->payloads_recu[0]=0 last_coder_type=255
(510104:000387) send_sip_successful_response_with_SDP
(510104:000388) remp_SDP_one_algo direction 0
(510104:000389) sdp_transparency_hardwareless neqt (1726) hinfo (0)
(510104:000390) sdp_transparency_hardwareless index (-1)
(510104:000391) !!!!!send_sip save_payload BEFORE 255 AFTER 0 neqt 1726
(510104:000392) SIP : [send_to_motor] ipcSend resultat : 0 sur eqt : 1726
(510104:000393) SIP : [ipc_send] envoi du message : 10765.
(510104:000394) +------------------------------------------------------------+
(510104:000395) | Message sent UA (neqt : 1726-0) ----> SIP
(510104:000396) | Successful 200
(510104:000397) |RELATIVE REQUEST : INVITE
(510104:000398) +------------------------------------------------------------+
(510104:000399) | SDP :
(510104:000400) | @IP:port = 10.20.10.1:32248
(510104:000401) | ALGOS :
(510104:000402) | PCMA
(510104:000403) | DTMF : 101
(510104:000404) | DIRECTION : SEND & RECEIVE
(510104:000405) | AssertedAddress : <> ÿÿÿÿÿÿden @10.10.10.1:5060
(510104:000406) +------------------------------------------------------------+
(510104:000407) SIP : ctrl_sip evt : 10754.
(510104:000408) +------------------------------------------------------------+
(510104:000409) | Message received SIP ----> UA (neqt : 1726)
(510104:000410) | ACK
(510104:000411) +------------------------------------------------------------+
(510104:000412) modif_grammaire_ipns AR_CONNEXION remp(1726) = 1
(510104:000413) No need for RE_INVITE invoking ==> in_communication
(510104:000414) neqt(1726) PROCEDURE comm_save_sip() neqt=25259636
(510104:000415) SIP : in_communication_init_data
(510104:000416) SIP : ALLOWUPDATE : CSU(1726) set_remote_allow_update 0 -> 0
(510104:000417) set_update_allowed : sipAllowUpdate(1726) => before 0 After 1
(510104:000418) is_ems_ext_gw-->neqt=1790,Result=0
(510105:000419) REMOTE : declenche_remote_network authentified(neqt=1790)= 1
(510105:000420) REMOTE ------Cas local (authentified=1) ------
(510105:000421) remote_cc_link_setup_ind_idle-->neqt_sip=1790
(510105:000422) is_ems_ext_gw-->neqt=1790,Result=0
(510105:000423) event_init_screen_mem : line 1 tscreen ' 24/03/15 10:51'
(510105:000424) event_init_screen_mem : line 1 tscreen ' 24/03/15 10:51'
(510105:000425) MEVO : update_type_of_set neqt 1886
(510105:000426) INIT MEVO : uti_inidcom init mevo neqt 1886
(510105:000427) event_init_screen_mem : line 1 tscreen ' 24/03/15 10:51'
(510105:000428) MEVO : update_type_of_set neqt 1886
(510105:000429) INIT MEVO : uti_inidcom init mevo neqt 1886
(510105:000430) Second inidcom malgre chainage
(510105:000431) Chainage conserve avec vg_neqt = -1 emettant message 65535;
(510105:000432) SIP : isMulticodecNetwork 0
(510105:000434) event_init_screen_mem : line 1 tscreen ' 24/03/15 $$$$$'
(510105:000435) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510105:000436) event_init_screen_mem : line 1 tscreen 'Ring : '
(510105:000438) event_init_screen_mem : line 1 tscreen '6 '
(510105:000439) event_init_screen_mem : line 1 tscreen '60 '
(510105:000440) SIP : isMulticodecNetwork 0
(510135:000442) event_init_screen_mem : line 1 tscreen 'Ring : '
(510150:000444) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510150:000445) event_init_screen_mem : line 1 tscreen 'Ring : '
(510150:000447) SIP : isMulticodecNetwork 0
(510161:000450) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510161:000451) event_init_screen_mem : line 1 tscreen 'Externt '
(510167:000454) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510167:000455) event_init_screen_mem : line 1 tscreen '0 '
(510170:000458) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510170:000459) event_init_screen_mem : line 1 tscreen '07 '
(510170:000460) depart_t2_ok(100,0) : monlap 2
(510170:000461) depart_t2_ok On est la .....
(510170:000462) depart_t2_ok result=1
(510170:000463) depart_t2_ok(100,30) : monlap 1
(510170:000464) depart_t2_ok On est la .....
(510170:000465) depart_t2_ok result=1
(510170:000466) depart_t2_ok(100,0) : monlap 2
(510170:000467) depart_t2_ok On est la .....
(510170:000468) depart_t2_ok result=1
(510170:000469) depart_t2_ok(100,30) : monlap 1
(510170:000470) depart_t2_ok On est la .....
(510170:000471) depart_t2_ok result=1
(510170:000472) depart_t2_ok(100,0) : monlap 2
(510170:000473) depart_t2_ok On est la .....
(510170:000474) depart_t2_ok result=1
(510170:000475) depart_t2_ok(100,30) : monlap 1
(510170:000476) depart_t2_ok On est la .....
(510170:000477) depart_t2_ok result=1
(510170:000478) depart_t2_ok(100,0) : monlap 2
(510170:000479) depart_t2_ok On est la .....
(510170:000480) depart_t2_ok result=1
(510170:000481) SIP : isMulticodecNetwork 0
(510170:000484) depart_t2_ok(100,30) : monlap 1
(510170:000485) depart_t2_ok On est la .....
(510170:000486) depart_t2_ok result=1
(510170:000487) ---> ptdemi->neqt 1886
(510170:000488) ---> with_terminaison->dtyterm 13
(510170:000489) set_update_allowed : sipAllowUpdate(160) => before 0 After 0
(510170:000490) INIT MEVO : uti_inidcom init mevo neqt 160
(510170:000491) neqttouc neqt=160 nekip=1886 toucacod=1
(510170:000492) neqttouc result=100075e en Hexa !!!
(510170:000493) Init_reInviteWoSDP(160) => Not_applicable
(510170:000494) set_typeOfCodecNego(160) => defaultNego
(510170:000495) set_SipScenario(160) BEFORE Scenario_undefined AFTER Scenario_undefined
(510170:000496) set_faxProcType(160) => T38_only
| (510170:000497) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 45 desti: 0 source: 15 cryst: 2 cpl: 4 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 04 da
| IE:[6c] CALLING_NUMBER (l=10) -> 21 81 Num : 18188584
| IE:[70] CALLED_NUMBER (l=4) -> 81 Num : 077
| IE:[7d] HLC (l=2) 91 81
(510170:000498) sendisdn: update ip_data_to_send = false !!!!!
| (510173:000499) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 4 us: 0 term: 1 type a5
| tei: 0 >>>> message received : SETUP ACK [0d] Call ref : 84 da
| IE:[18] CHANNEL (l=3) a9 83 81 -> T2 : B channel 1 exclusive
(510173:000501) sip_behind_ice-->neqt=160,Result=0
(510173:000502) sip_behind_ice-->neqt=1886,Result=0
(510173:000503) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510173:000504) Exist_RCL_link-->Result=1,dtmf_direction=1
(510173:000505) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510173:000506) SIP : isMulticodecNetwork 0
(510173:000507) SIP : isMulticodecNetwork 0
(510173:000510) SIP : isMulticodecNetwork 0
(510173:000519) Marhaban bikom dans le monde SIP : dtmf_payload(1790)= 101
(510173:000520) is_ems_ext_gw-->neqt=1790,Result=0
(510173:000521) send_cpl_connect_rtp_direct-->dtmf_direction=1
(510173:000522) get_cfl_and_faxtype neqt(1790)
(510173:000523) get_cfl_and_faxtype: SIP ou ABCIP cfl 0x60 faxtype 0
(510173:000530) sip_behind_ice-->neqt=160,Result=0
(510173:000531) sip_behind_ice-->neqt=1886,Result=0
(510173:000532) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510173:000533) Exist_RCL_link-->Result=1,dtmf_direction=1
(510173:000534) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510173:000535) SIP : isMulticodecNetwork 0
(510173:000536) event_init_screen_mem : line 1 tscreen '077 '
(510173:000537) ghost_z_make_normal_sip_call-->Result=0
(510177:000539) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510177:000540) event_init_screen_mem : line 1 tscreen '077 '
| (510177:000541) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 4 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : INFORMATION [7b] Call ref : 04 da
| IE:[70] CALLED_NUMBER (l=2) -> 81 Num : 1
(510177:000542) sendisdn: update ip_data_to_send = false !!!!!
(510179:000543) event_init_screen_mem : line 1 tscreen '0771 '
(510179:000544) sip_behind_ice-->neqt=160,Result=0
(510179:000545) sip_behind_ice-->neqt=1886,Result=0
(510179:000546) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510179:000547) Exist_RCL_link-->Result=1,dtmf_direction=1
(510179:000548) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510179:000549) SIP : isMulticodecNetwork 0
(510182:000551) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510182:000552) event_init_screen_mem : line 1 tscreen '0771 '
| (510182:000553) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| IE:[70] CALLED_NUMBER (l=2) -> 81 Num : 2
(510182:000554) sendisdn: update ip_data_to_send = false !!!!!
(510183:000555) sip_behind_ice-->neqt=160,Result=0
(510183:000556) sip_behind_ice-->neqt=1886,Result=0
(510183:000557) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510183:000558) Exist_RCL_link-->Result=1,dtmf_direction=1
(510183:000559) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510183:000560) SIP : isMulticodecNetwork 0
(510186:000562) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510186:000563) event_init_screen_mem : line 1 tscreen '07712 '
| (510186:000564) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
(510186:000565) sendisdn: update ip_data_to_send = false !!!!!
(510188:000566) sip_behind_ice-->neqt=160,Result=0
(510188:000567) sip_behind_ice-->neqt=1886,Result=0
(510188:000568) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510188:000569) Exist_RCL_link-->Result=1,dtmf_direction=1
(510188:000570) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510188:000571) SIP : isMulticodecNetwork 0
(510190:000573) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510190:000574) event_init_screen_mem : line 1 tscreen '077122 '
| (510190:000575) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
(510190:000576) sendisdn: update ip_data_to_send = false !!!!!
(510192:000577) sip_behind_ice-->neqt=160,Result=0
(510192:000578) sip_behind_ice-->neqt=1886,Result=0
(510192:000579) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510192:000580) Exist_RCL_link-->Result=1,dtmf_direction=1
(510192:000581) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510192:000582) SIP : isMulticodecNetwork 0
(510193:000584) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510193:000585) event_init_screen_mem : line 1 tscreen '0771221 '
| (510193:000586) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
(510193:000587) sendisdn: update ip_data_to_send = false !!!!!
(510195:000588) sip_behind_ice-->neqt=160,Result=0
(510195:000589) sip_behind_ice-->neqt=1886,Result=0
(510195:000590) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510195:000591) Exist_RCL_link-->Result=1,dtmf_direction=1
(510195:000592) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510195:000593) SIP : isMulticodecNetwork 0
(510199:000595) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510199:000596) event_init_screen_mem : line 1 tscreen '07712211 '
| (510199:000597) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
(510199:000598) sendisdn: update ip_data_to_send = false !!!!!
(510201:000599) sip_behind_ice-->neqt=160,Result=0
(510201:000600) sip_behind_ice-->neqt=1886,Result=0
(510201:000601) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510201:000602) Exist_RCL_link-->Result=1,dtmf_direction=1
(510201:000603) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510201:000604) SIP : isMulticodecNetwork 0
(510202:000606) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510202:000607) event_init_screen_mem : line 1 tscreen '077122112 '
| (510202:000608) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
(510202:000609) sendisdn: update ip_data_to_send = false !!!!!
| (510203:000610) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 4 us: 0 term: 1 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 84 da
(510203:000611) sip_behind_ice-->neqt=160,Result=0
(510203:000612) sip_behind_ice-->neqt=1886,Result=0
(510203:000613) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510203:000614) Exist_RCL_link-->Result=1,dtmf_direction=1
(510203:000615) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510203:000616) SIP : isMulticodecNetwork 0
(510203:000617) event_init_screen_mem : line 1 tscreen '0771221122 '
(510203:000618) achemine : ptdemi->neqt = 1886
(510203:000619) ghost_z_make_normal_sip_call-->Result=0
| (510216:000620) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 4 us: 0 term: 1 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 84 da
| IE:[1e] PROGRESS_ID (l=2) 84 88
(510216:000621) event_init_screen_mem : line 1 tscreen 'TRANSPARENT DTMF'
| (510219:000622) Concatenated-Physical-Event :
| long: 25 desti: 0 source: 0 cryst: 2 cpl: 4 us: 0 term: 1 type a5
| tei: 0 >>>> message received : CONNECT (07) Call ref : 84 da
| IE:[29] DATE (l=5) -> date : 24 / 03 / 15 10:59
(510219:000623) est_ce_maitre-->send_ct_setup=0 ringing_transfer_scenario=0 explmevo=0
(510219:000624) receive_sip_transfer(160) etat_t2=4 rop_pending=0 global_state=0 (0x0)
(510219:000625) SIP : isMulticodecNetwork 0
| (510219:000626) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 4 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : CONNECT ACK (0f) Call ref : 04 da
(510219:000627) sendisdn: update ip_data_to_send = false !!!!!
(510219:000628) sip_behind_ice-->neqt=160,Result=0
(510219:000629) sip_behind_ice-->neqt=1886,Result=0
(510219:000630) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510219:000631) Exist_RCL_link-->Result=1,dtmf_direction=1
(510219:000632) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510219:000633) SIP : isMulticodecNetwork 0
(510219:000634) neqttouc neqt=160 nekip=1886 toucacod=1
(510219:000635) neqttouc result=100075e en Hexa !!!
(510219:000636) !!!!!trunk_convers neqt=160 enc_on_my_side(0) enc_on_opposite_side(0)
(510219:000637) SIP : ALLOWUPDATE : CSU(160) set_remote_allow_update 0 -> 0
(510219:000638) event_init_screen_mem : line 1 tscreen 'TRANSPARENT DTMF'
(510219:000639) sip_behind_ice-->neqt=1886,Result=0
(510219:000640) sip_behind_ice-->neqt=160,Result=0
(510219:000641) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510219:000642) Exist_RCL_link-->Result=1,dtmf_direction=1
(510219:000643) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510219:000644) SIP : isMulticodecNetwork 0
(510219:000645) numunpack_trace: 00771221122
(510219:000646) from_same_nb_in_mes : nulog=213,numero_lg=11
(510221:000647) event_init_screen_mem : line 1 tscreen 'Samtal '
(510221:000648) sip_behind_ice-->neqt=1886,Result=0
(510221:000649) sip_behind_ice-->neqt=160,Result=0
(510221:000650) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510221:000651) Exist_RCL_link-->Result=1,dtmf_direction=1
(510221:000652) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510221:000653) SIP : isMulticodecNetwork 0
(510221:000654) MEVO : rend_indice_mevo indice 126 numero trouve 1
(510221:000655) sip_behind_ice-->neqt=160,Result=0
(510221:000656) sip_behind_ice-->neqt=1886,Result=0
(510221:000657) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510221:000658) Exist_RCL_link-->Result=1,dtmf_direction=1
(510221:000659) Exist_RCL_On_Sip_TG neqt=1790 TRUE
(510221:000660) SIP : isMulticodecNetwork 0
(510221:000661) evtentrans
(510251:000662) SIP : Global_get_mcdu, unknown hostname
(510251:000663) SIP : Global_get_mcdu, unknown hostname
(510251:000664) SIP : Global_get_mcdu, unknown hostname
(510251:000665) SIP : Global_get_mcdu, unknown hostname
(510292:000668) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510306:000670) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510314:000672) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510321:000674) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510327:000676) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510334:000678) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510342:000679) event_init_screen_mem : line 1 tscreen 'MedflyttRstBrev'
(510342:000680) MEVO : update_type_of_set neqt 1967
(510342:000681) INIT MEVO : uti_inidcom init mevo neqt 1967
(510342:000682) event_init_screen_mem : line 1 tscreen '440 '
(510342:000683) MEVO : update_type_of_set neqt 57
(510342:000684) INIT MEVO : uti_inidcom init mevo neqt 57
(510342:000688) event_init_screen_mem : line 1 tscreen ' 24/03/15 11:00'
(510342:000689) MEVO : update_type_of_set neqt 1967
(510342:000690) INIT MEVO : uti_inidcom init mevo neqt 1967
(510342:000691) event_init_screen_mem : line 1 tscreen '440 '
(510342:000692) MEVO : update_type_of_set neqt 57
(510342:000693) INIT MEVO : uti_inidcom init mevo neqt 57
(510342:000696) event_init_screen_mem : line 1 tscreen '440 '
(510342:000697) MEVO : update_type_of_set neqt 57
(510342:000698) INIT MEVO : uti_inidcom init mevo neqt 57
(510342:000743) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000744) message_enregistrement() mess_enreg=0 autre_mess=0
(510342:000745) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:2-Cpl:2)
(510342:000746) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000747) message_enregistrement() mess_enreg=0 autre_mess=0
(510342:000752) event_init_screen_mem : line 1 tscreen 'MedflyttRstBrev'
(510342:000753) MEVO : update_type_of_set neqt 1884
(510342:000754) INIT MEVO : uti_inidcom init mevo neqt 1884
(510342:000755) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000756) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000757) MEVO : update_type_of_set neqt 1084
(510342:000758) INIT MEVO : uti_inidcom init mevo neqt 1084
(510342:000759) event_init_screen_mem : line 1 tscreen ' 24/03/15 11:00'
(510342:000760) MEVO : update_type_of_set neqt 1884
(510342:000761) INIT MEVO : uti_inidcom init mevo neqt 1884
(510342:000762) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000763) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000764) MEVO : update_type_of_set neqt 1084
(510342:000765) INIT MEVO : uti_inidcom init mevo neqt 1084
(510342:000766) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000767) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000768) MEVO : update_type_of_set neqt 1084
(510342:000769) INIT MEVO : uti_inidcom init mevo neqt 1084
(510342:000770) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000771) message_enregistrement() mess_enreg=0 autre_mess=0
(510342:000772) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:4-Cpl:0)
(510342:000773) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000774) message_enregistrement() mess_enreg=0 autre_mess=0
(510342:000775) event_init_screen_mem : line 1 tscreen 'MedflyttRstBrev'
(510342:000776) MEVO : update_type_of_set neqt 1972
(510342:000777) INIT MEVO : uti_inidcom init mevo neqt 1972
(510342:000778) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000779) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000780) MEVO : update_type_of_set neqt 1036
(510342:000781) INIT MEVO : uti_inidcom init mevo neqt 1036
(510342:000782) event_init_screen_mem : line 1 tscreen ' 24/03/15 11:00'
(510342:000783) MEVO : update_type_of_set neqt 1972
(510342:000784) INIT MEVO : uti_inidcom init mevo neqt 1972
(510342:000785) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000786) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000787) MEVO : update_type_of_set neqt 1036
(510342:000788) INIT MEVO : uti_inidcom init mevo neqt 1036
(510342:000789) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510342:000790) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510342:000791) MEVO : update_type_of_set neqt 1036
(510342:000792) INIT MEVO : uti_inidcom init mevo neqt 1036
(510342:000793) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000794) message_enregistrement() mess_enreg=0 autre_mess=0
(510342:000795) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:4-Cpl:0)
(510342:000796) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510342:000797) message_enregistrement() mess_enreg=0 autre_mess=0
(510343:000798) event_init_screen_mem : line 1 tscreen 'MedflyttRstBrev'
(510343:000799) MEVO : update_type_of_set neqt 1864
(510343:000800) INIT MEVO : uti_inidcom init mevo neqt 1864
(510343:000801) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510343:000802) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510343:000803) MEVO : update_type_of_set neqt 1104
(510343:000804) INIT MEVO : uti_inidcom init mevo neqt 1104
(510343:000805) event_init_screen_mem : line 1 tscreen ' 24/03/15 11:00'
(510343:000806) MEVO : update_type_of_set neqt 1864
(510343:000807) INIT MEVO : uti_inidcom init mevo neqt 1864
(510343:000808) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510343:000809) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510343:000810) MEVO : update_type_of_set neqt 1104
(510343:000811) INIT MEVO : uti_inidcom init mevo neqt 1104
(510343:000812) event_init_screen_mem : line 1 tscreen 'Medflytt > RstBrevlda24/03/15 $$$$$'
(510343:000813) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510343:000814) MEVO : update_type_of_set neqt 1104
(510343:000815) INIT MEVO : uti_inidcom init mevo neqt 1104
(510343:000816) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510343:000817) message_enregistrement() mess_enreg=0 autre_mess=0
(510343:000818) *** warning: no time-slot alloc/desalloc nedeed for this coupler (Cr:4-Cpl:0)
(510343:000819) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510343:000820) message_enregistrement() mess_enreg=0 autre_mess=0
(510346:000822) sip_no_need_allocate_RCL-->neqt=1790.Result=1
(510371:000824) recoit_rac_sip_en_com: neqt 1726
(510371:000825) SIP : ctrl_sip evt : 10755.
(510371:000826) +------------------------------------------------------------+
(510371:000827) | Message received SIP ----> UA (neqt : 1726)
(510371:000828) | BYE
(510371:000829) +------------------------------------------------------------+
(510371:000830) lib_messa_etab no=0 neqt=1726
(510371:000831) event_init_screen_mem : line 1 tscreen 'Ton '
(510371:000832) MEVO : jonct_dtmf Result 0
(510371:000833) event_init_screen_mem : line 1 tscreen 'Ton '
| (510371:000834) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 04 da
| IE:[08] CAUSE (l=2) 81 90 -> [90] NORMAL CALL CLEARING
(510371:000835) sendisdn: update ip_data_to_send = false !!!!!
(510371:000836) event_init_screen_mem : line 1 tscreen ' 24/03/15 $$$$$'
(510371:000837) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510371:000838) MEVO : update_type_of_set neqt 1024
(510371:000839) INIT MEVO : uti_inidcom init mevo neqt 1024
(510371:000840) event_init_screen_mem : line 1 tscreen ' 24/03/15 $$$$$'
(510371:000841) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510371:000842) MEVO : update_type_of_set neqt 1024
(510371:000843) INIT MEVO : uti_inidcom init mevo neqt 1024
(510371:000844) put_rtp_info end 1726 local.wc=0 distant.wc=0
(510371:000845) send_sip_successful->called_entity=1000
(510371:000846) SIP : [send_to_motor] ipcSend resultat : 0 sur eqt : 1726
(510371:000847) SIP : [ipc_send] envoi du message : 10765.
(510371:000848) +------------------------------------------------------------+
(510371:000849) | Message sent UA (neqt : 1726-0) ----> SIP
(510371:000850) | Successful 200
(510371:000851) |RELATIVE REQUEST : BYE
(510371:000852) | No SDP
(510371:000853) +------------------------------------------------------------+
(510371:000854) SIP : [send_to_motor_eqt_release] ipcSend resultat : 0 sur eqt : 1726
(510371:000855) SIP : [ipc_send] envoi eqt release 1726
(510371:000856) decrement_nb_abc_sip_cnx
(510371:000857) SIP mise_a_jour_des_canaux ind=63 neqt=1726 allocation=0
(510371:000858) delete_B_from_list neqtB 1726
(510371:000859) set_SipScenario(1726) BEFORE Scenario_undefined AFTER Scenario_undefined
(510371:000860) send_sip 1726 mess 4 voip_en_fast_start 1 BEGIN
(510371:000861) SIP : [send_to_motor] ipcSend resultat : 0 sur eqt : 1726
(510371:000862) SIP : [ipc_send] envoi du message : 10755.
(510371:000863) +------------------------------------------------------------+
(510371:000864) | Message sent UA (neqt : 1726-0) ----> SIP
(510371:000865) | BYE
(510371:000866) +------------------------------------------------------------+
(510371:000867) send_sip 1726 mess 4 voip_en_fast_start 1 END
(510371:000868) envoijustif : ptdemi->neqt=1790
(510371:000869) decrement_nb_abc_sip_cnx
(510371:000870) SIP mise_a_jour_des_canaux ind=0 neqt=1790 allocation=0
(510371:000880) SIP mise_a_jour_des_canaux ind=0 neqt=1790 allocation=0
(510371:000881) delete_B_from_list neqtB 1790
(510371:000882) set_SipScenario(1790) BEFORE Scenario_undefined AFTER Scenario_undefined
| (510372:000883) Concatenated-Physical-Event :
| tei: 0 >>>> message received : RELEASE [4d] Call ref : 84 da
(510372:000884) envoijustif : ptdemi->neqt=160
(510372:000885) WITH_tephjust->numan[1]=0
| (510372:000886) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| tei: 0 <<<< message sent : REL COMP [5a] Call ref : 04 da
(510372:000887) sendisdn: update ip_data_to_send = false !!!!!
(510372:000890) set_SipScenario(160) BEFORE Scenario_undefined AFTER Scenario_undefined
| (510378:000891) Concatenated-Physical-Event :
| long: 48 desti: 0 source: 0 cryst: 2 cpl: 13 us: 0 term: 0 type a5
| tei: 0 >>>> message received : SETUP [05] Call ref : 00 54
|SENDING COMPLETE
| IE:[18] CHANNEL (l=3) a1 83 85 -> T2 : B channel 5 preferred
| IE:[6c] CALLING_NUMBER (l=11) -> 21 83 Num : 703368410
| IE:[70] CALLED_NUMBER (l=4) -> c1 Num : 362
(510378:000892) set_update_allowed : sipAllowUpdate(328) => before 0 After 0
(510378:000893) INIT MEVO : uti_inidcom init mevo neqt 328
(510378:000894) Init_reInviteWoSDP(328) => Not_applicable
(510378:000895) set_typeOfCodecNego(328) => defaultNego
(510378:000896) set_SipScenario(328) BEFORE Scenario_undefined AFTER Scenario_undefined
(510378:000897) set_faxProcType(328) => T38_only
(510378:000899) SIP : isMulticodecNetwork 0
| (510378:000901) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 23 desti: 0 source: 15 cryst: 2 cpl: 13 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : CALL PROC (02) Call ref : 80 54
| IE:[18] CHANNEL (l=3) a9 83 85 -> T2 : B channel 5 exclusive
(510378:000902) sendisdn: update ip_data_to_send = false !!!!!
(510378:000903) MEVO : sauve_categorie_mevo monneqt 328 neqt 328
(510378:000904) MEVO : option1 1 ,2 1
(510378:000905) MEVO : rend_categorie_mevo cat=1
(510378:000906) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000907) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000908) is_abbreviated result = 0
(510378:000909) MEVO : rend_mcdu_mevo indice 255,nulog 50
(510378:000910) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000911) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000912) is_abbreviated result = 0
(510378:000913) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000914) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000915) is_abbreviated result = 0
(510378:000916) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000917) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000918) is_abbreviated result = 0
(510378:000919) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000920) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000921) is_abbreviated result = 0
(510378:000922) MEVO : renv_successifs(2) mcdu_arrivee 362
(510378:000923) MEVO : renv_successifs(1) mcdu_arrive 362 ,mcdu_compose 362 ,Result 0
(510378:000924) is_abbreviated result = 0
(510378:000925) event_init_screen_mem : line 1 tscreen ' 24/03/15 $$$$$'
(510378:000926) event_init_screen_mem : line 2 tscreen ' .... .... .... .... .... '
(510378:000927) MEVO : renv_successifs(2) mcdu_arrivee
(510378:000928) MEVO : renv_successifs(1) mcdu_arrive ,mcdu_compose ,Result 0
(510378:000929) is_abbreviated result = 0
(510378:000930) neqttouc neqt=1064 nekip=1064 toucacod=1
(510378:000931) neqttouc result=1000428 en Hexa !!!
(510378:000932) MEVO : renv_successifs(2) mcdu_arrivee
(510378:000933) MEVO : renv_successifs(1) mcdu_arrive ,mcdu_compose ,Result 0
(510378:000934) is_abbreviated result = 0
(510378:000935) MEVO : update_type_of_set neqt 1064
(510378:000936) INIT MEVO : uti_inidcom init mevo neqt 1064
(510378:000937) decauto_possible catexploit result=1 neqt=1064
(510378:000938) en_face_de_rsvp_decauto result 0
(510378:000939) en_face_de_sympac_decauto result 0
(510378:000940) en_face_de_dtmfserver_decauto result 0
(510378:000941) decauto_possible catexploit result=1 neqt=1064
(510378:000942) en_face_de_rsvp_decauto result 0
(510378:000943) en_face_de_sympac_decauto result 0
(510378:000944) en_face_de_dtmfserver_decauto result 0
(510378:000945) ptdemi->nummcdu 16778280
| (510378:000946) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 18 desti: 0 source: 15 cryst: 2 cpl: 13 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : ALERT (01) Call ref : 80 54
(510378:000947) sendisdn: update ip_data_to_send = false !!!!!
(510378:000948) event_init_screen_mem : line 1 tscreen ' 24/03/15 08:06'
(510378:000949) MEVO : renv_successifs(2) mcdu_arrivee
(510378:000950) MEVO : renv_successifs(1) mcdu_arrive ,mcdu_compose ,Result 0
(510378:000951) is_abbreviated result = 0
(510378:000952) MEVO : update_type_of_set neqt 1906
(510378:000953) INIT MEVO : uti_inidcom init mevo neqt 1906
(510378:000954) decauto_possible result=0 neqt=1906 pb_tandem=1
(510378:000955) decauto_possible result=0 neqt=1906 pb_tandem=1
(510378:000956) MEVO : update_type_of_set neqt 1984
(510378:000957) INIT MEVO : uti_inidcom init mevo neqt 1984
(510378:000958) depart_t2_ok(101,0) : monlap 3
(510378:000959) depart_t2_ok On est la .....
(510378:000960) depart_t2_ok result=1
(510378:000961) depart_t2_ok(101,0) : monlap 3
(510378:000962) depart_t2_ok On est la .....
(510378:000963) depart_t2_ok result=1
(510378:000964) depart_t2_ok(101,0) : monlap 3
(510378:000965) depart_t2_ok On est la .....
(510378:000966) depart_t2_ok result=1
(510378:000967) depart_t2_ok(101,0) : monlap 3
(510378:000968) depart_t2_ok On est la .....
(510378:000969) depart_t2_ok result=1
(510378:000970) modifIfRemoteExtGhostZ-->remote_nulog=266,neqt_calling=328
(510378:000971) ---> ptdemi->neqt 1984
(510378:000972) ---> with_terminaison->dtyterm 12
(510378:000973) abpqmcdu_trace: 70336841
(510378:000974) isdnmcdu_trace: 703368410
(510378:000975) set_update_allowed : sipAllowUpdate(392) => before 0 After 0
(510378:000976) INIT MEVO : uti_inidcom init mevo neqt 392
(510378:000977) Init_reInviteWoSDP(392) => Not_applicable
(510378:000978) set_typeOfCodecNego(392) => defaultNego
(510378:000979) set_SipScenario(392) BEFORE Scenario_undefined AFTER Scenario_undefined
(510378:000980) set_faxProcType(392) => T38_only
| (510378:000981) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 58 desti: 0 source: 15 cryst: 2 cpl: 13 us: 8 term: 1 type a5
| tei: 0 <<<< message sent : SETUP [05] Call ref : 1a 5b
| IE:[1e] PROGRESS_ID (l=2) 80 83
| IE:[6c] CALLING_NUMBER (l=11) -> 21 81 Num : 703368410
| IE:[70] CALLED_NUMBER (l=11) -> a1 Num : 0702908633
| [a1] Sending complete
(510378:000983) sendisdn: update ip_data_to_send = false !!!!!
| (510380:000984) Concatenated-Physical-Event :
| long: 23 desti: 0 source: 0 cryst: 2 cpl: 13 us: 0 term: 1 type a5
| tei: 0 >>>> message received : CALL PROC (02) Call ref : 9a 5b
(510410:000986) SIP : ctrl_sip evt : 21792.
(510410:000987) +------------------------------------------------------------+
(510410:000988) | Message received SIP ----> UA (neqt : 1726-72)
(510410:000989) +------------------------------------------------------------+
(510410:000990) SIP : [send_to_motor_eqt_release] ipcSend resultat : 0 sur eqt : 1726
(510410:000991) SIP : [ipc_send] envoi eqt release 1726
(510410:000992) decrement_nb_abc_sip_cnx
(510410:000993) SIP mise_a_jour_des_canaux ind=63 neqt=1726 allocation=0
(510410:000994) delete_B_from_list neqtB 1726
(510410:000995) set_SipScenario(1726) BEFORE Scenario_undefined AFTER Scenario_undefined
(510410:000996) decrement_nb_abc_sip_cnx
(510410:000997) SIP mise_a_jour_des_canaux ind=0 neqt=1790 allocation=0
(510410:000998) delete_B_from_list neqtB 1790
(510410:000999) set_SipScenario(1790) BEFORE Scenario_undefined AFTER Scenario_undefined
| (510416:001000) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 13 us: 0 term: 0 type a5
| tei: 0 >>>> message received : DISCONNECT [45] Call ref : 00 53
| IE:[08] CAUSE (l=2) 80 90 -> [90] NORMAL CALL CLEARING
(510416:001001) event_init_screen_mem : line 1 tscreen '0706860137 '
(510416:001002) event_init_screen_mem : line 2 tscreen ' Frf. Park Spra Ton Vnt '
(510416:001003) event_init_screen_mem : line 1 tscreen '0706860137 '
(510416:001004) event_init_screen_mem : line 2 tscreen ' Frf. Park Spra Ton Vnt '
(510416:001009) event_init_screen_mem : line 1 tscreen ' Facilitet '
(510416:001010) event_init_screen_mem : line 2 tscreen ' SnabbV Spra '
(510416:001011) MEVO ENREG : fin_enr_pos neqt 58
| (510416:001015) 1331: Send_IO1 (link-nbr=2, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 13 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : RELEASE [4d] Call ref : 80 53
(510416:001016) sendisdn: update ip_data_to_send = false !!!!!
| (510417:001017) Concatenated-Physical-Event :
| long: 18 desti: 0 source: 0 cryst: 2 cpl: 13 us: 0 term: 0 type a5
| tei: 0 >>>> message received : REL COMP [5a] Call ref : 00 53
(510417:001018) envoijustif : ptdemi->neqt=330
(510417:001019) WITH_tephjust->numan[1]=0
(510417:001022) set_SipScenario(330) BEFORE Scenario_undefined AFTER Scenario_undefined
| (510417:001023) Concatenated-Physical-Event :
| long: 22 desti: 0 source: 0 cryst: 2 cpl: 13 us: 0 term: 1 type a5
| tei: 0 >>>> message received : ALERT (01) Call ref : 9a 5b
(510417:001024) sip_gw_ext_can_support_sip_info :Result=0
(510417:001025) sip_ems_with_rfc2833-->disa_for_remote_ext=1
(510417:001026) sip_ems_with_rfc2833-->Result=0
(510417:001027) sip_no_need_allocate_RCL-->neqt=392.Result=0
(510417:001028) INIT MEVO : uti_inidcom init mevo neqt 2061
(510417:001029) SIP : isMulticodecNetwork 0
(510417:001031) MEVO : sauve_categorie_mevo
(510417:001032) MEVO : sauve_categorie_mevo monneqt 1984 neqt 392
(510417:001033) MEVO : option1 1 ,2 1
(510417:001034) event_init_screen_mem : line 1 tscreen '1:0703368410 '
(510433:001036) event_init_screen_mem : line 1 tscreen ' V.V. lgg p luren '
(510433:001037) event_init_screen_mem : line 2 tscreen ' '
(510433:001039) event_init_screen_mem : line 1 tscreen ' V.V. lgg p luren '
(510433:001040) event_init_screen_mem : line 2 tscreen ' '
(510433:001042) message_enregistrement() box_state=6 ML_NOT_MSG=6
(510433:001043) message_enregistrement() mess_enreg=0 autre_mess=0
mtracer started ...
|SENDING COMPLETE
- frank
So the issue is that LYNC users can't send DTMF to an external call , if I understand correctly ?
Have you tried to use DTMF suffix and see if it works ?
or try end-end trnasparency and dtmf end-end to transp
or it's always offred check screen'
pax
Yes, not to external call, not to an internal OXE extension. The DTMF-tones only works over the SIP-trunk to the OXE dial tone function. So the Lync user can dial the external number (with DTMF tons) but then when the call is answered DTMF- tones are filter away to the end user. This only occurs when the call is routed via DISA substitution. If I route it direct thru the OXE without DISA it works. But this is not a permanent option in my case. Also the DTMF suffix is completely ignored.frank wrote:So the issue is that LYNC users can't send DTMF to an external call , if I understand correctly ?
- frank
I do not use lync. I am just trying to understand your topology. So LYNC is connected through SIP trunk to OXE:
- Did you use ABC-F or ISDN-ALL Countries ?
- Did you use the internal gateway only, or did you use external gateway ?
If you go through a visa substitution, call an external number, the remote party picks up, then from sync enter the DTMF suffixe, that does not work ?
pax
frank wrote:I do not use lync. I am just trying to understand your topology. So LYNC is connected through SIP trunk to OXE:
I am using a SIP trunk in the OXE site using ABC-F Q931 signal variant connected to an external SIP external GW configured to use TCP and G711 codec negotiation. From the Lync 2013 side I address the OXE as a PSDN-GW using right corresponding ports with the OXE (eg. 5060)
Yes that’s right, when pressing *# from Lync like on a digital phone it is completely ignored.
- frank
ABC-F is more likely used for internal connections (like other ALU systems).
Did you try with ISDN-All-Countries ?
try to create prefix dtmf end to end transparency that you will use during conv or anticipated dtmf end to end suffix tnat you can use during call set up digit are sent in dtmf when conv
