Restore Ticket from A4760
generalkiki
Good morning to all guys, in your experience alcatel 4760 saves the old ticket in a zip file or something after the 90 days are configured on the system? I need to retrieve the old ticket even in 2010 but are not sure you can do. Can you help?
Thank you very much for your time.
L_lefante
Re: Restore Ticket from A4760
I dont know how can you check it from 4760, but maybe you can search the oldest ticket saved in OXE with the command accview.
If you did not configure 4760 to keep archived tickets for 5 years so there is no way to get them back. They are deleted from DB and from archives. 4760 keeps them in /4760_ARC/accounting/ folder - you can check the files there.
Several years ago i used to do that you wolud like to do now...
I found that a folder contains the tickets, but couldn't remember the exact directory, but i suppose the location is somewhere the USR4 or USR3 folders...
The tickets stored in .dat files, as far as i know. The file names are beginning with TAXA and several random characters, it is sure. If you find this folder, you could download to the accounting PC, and put them into a "collector's" folder, the temporary folder which is used by the collector process. I think the documentation is mention this process... I find that the 4760 does not delete these files after 90 days. I found 1-2 years old files.
/usr4/account - but in real PBX - I think exist stored files for 30 (by default) days or more (if managed) but for many yeas storage - we will have problem with partition capacities.
Yesterday I checked some of my PBX, and it has tickets which are 1 years old. But it is a small office one.
A larger one I just checked contains ~6 months old tickets. It handles ~500 users.
And yes, the folder is USR4/TRAFFIC. The files are TAXAXYXY.dat files. You have to put htem into 4760's collector folder, and start importing tickets.
Hi Alex,alex wrote:If you did not configure 4760 to keep archived tickets for 5 years so there is no way to get them back. They are deleted from DB and from archives. 4760 keeps them in /4760_ARC/accounting/ folder - you can check the files there.
Could you specify where this configuration must made?I have a 4760 rel 5.2
I have registers only for the last 5 months on /4760_ARC/accounting/
Thanks in advance.
M
for 4760
go to directorymodul/system /server name/server name /accountting
item number of days by default value is 94D ( 94 days)
correction
directorymodul/system /server name/servers/server name /accountting
item is clean up delay
same as oxe becareful for the data partition where archives if you put very huge value of clean up delay
