omniswitch 6250p24 crash
furiousfifou
Post by furiousfifou »
Hello
I have a problem with a Omniswitch 6250p24. After power loss, the switch doesn't boot, all ethernet led are lit immediately. It's impossible to connect with the console port.
Led "OK" and led "PR1" are down.
The switch is not stacked.
the firmware version is 6.6.4.177.R01
Is it possible to reinstall flash with any console connection ?
Re: omniswitch 6250p24 crash
this is a known issue... as attachment a techtip.
hope this will help you also at 6250-
furiousfifou
I don't know what, i not have permission for this attachement, have you a another way to send it ?
Thank you
devnull
Post by devnull »
If you can't see anything on the console at all, the doc that silvio sent will be no help, as this describes a software-error, but requires some uboot/miniboot magic.
If you can't see anything on console you will have to RMA it.
mez77
Post by mez77 »
Thanks,but i can't find the firmware.
Return to “OmniSwitch 6250”
