Installing of OXE on IBM x3250-M5
sayuri88
Post by sayuri88 »
Did anyone did a successful installation of OXE R11.1 (l130123i) on IBM x3250-M5 Appliance Server?
i got the following error (No Drive Present) please see attached
Followed the Step on system documentation to set IBM x3250-M5 Bios
oxe11.1_im_ApplianceServer_8AL91029USAE_1_en.pdf
but still cannot install
Re: Installing of OXE on IBM x3250-M5
Try changing SATA to Legacy on BIOS
sayuri88
Post by sayuri88 »
Yap, Configured the onboard SATA ports as IDE,
and configure IDE mode as Native Mode
as instructed in the System documentation
problem is my BIOS version is 1.06 and ALU Test case BIOS is 1.01
FROM ALU Support....
I tested OXE installation on our IBM M5 without any trouble.
My IBM reference is IBM M5 3250
in Bios machine model is 5358234
memory 4 Gb
firmware version : 1.01
mmateus60
Post by mmateus60 »
Good night, we have the same error ( No drive Present ) , when trying to install release 11.0 , a Server HP dl320e Gen8. We have done what is in pdf IBM. Any help thank you very much.
sayuri88
Post by sayuri88 »
Manage to solve the problem by bypassing the SAS RAID Card in the x3259-M5,
Alcatel OXE R11.1 does not support IBM Raid
nimeshsbhatt
Post by nimeshsbhatt »
Did any one of you manage to solve with X 3250 M5. Part code 5458 AC1, the ale knowledge base mentioned that R& D and tested only with 5458 Z34, I do not understnad the approach of the ALE , they want the sites engineers to be Lenovo presales design experts as well.
