Configure CALL LOG feature on oxe R11
jpissot
Post by jpissot »
I want to activate CALL LOG feature on an R11 OXE.
I have enabled Call Log Server : System\Other System Params\Local Facilities Parameters\Enable Call Log Server.
I've created a prefix "Call Log" (set feature) and I've authorised the feature on Phone Facilities Categories.
When I compose the prefix, message "Service not Authorized".
I don't find any documentation on BPWS for Call Log?
Do you know the procedure?
Thank you.
Re: Configure CALL LOG feature on oxe R11
Works only on IP Touch Extended Edition or 80xx...
swinstu
Post by swinstu »
I also cannot get it working on R11.2.2 on a 8028. It is enabled in call log server (true) and users tel facilities category. Prefix #83 also created. get feature rejected after simulating some test calls and trying to use call log (button configured with #83). Also does not appear from message light key of answered calls.
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
swinstu
Post by swinstu »
After handset restart I have been able to get the call log feature to work but only by going through the mail button and pressing call log softkey. The prefix key still says "feature rejected" even after cross checking the content.
SWINSTU
ACSE OXE R12.1
HUSSAINQCS
Post by HUSSAINQCS »
I can able to access call log prefix in 8028 in R11.1
Is help required for Any body ?
Return to “Specific Telephone Services”
