OTMS-v with external Flexlm
karlefo
Post by karlefo »
Hi, I have just installed a OTMS- virtualized with a main external flexlm and a backup external flexlm (virtualized too).
I have received two .ice files (each one loaded in each flexlm external server, associated to a two dongle) and, a .swk file for the oxe (virtualized too)
When I installed the OTMS, I skipped the license step.
The installation was successfully, but now I need to load a license in OTMS.
Anyone knows how is the procedure for licensing the OTMS-v?
I just have got two .ice files loaded on every flexlm and work properly for the oxe.
Thanks for help.
tgn
Re: OTMS-v with external Flexlm
Post by tgn »
in postinstallation you have to put in a license server.
you can recognize this with
grep -i flex /var/data/bics/bics.conf
in directory $LICENSES_HOME you have to put a copy of the *.ice file from the responsible license server and in addition a file alchostid.cfg . the file alchostid.cfg must contain the OTID=XXXXXXXXXX without a carriage return. you can read out your otid with
grep -i otid $LICENSES_HOME/*.ice
regards...
karlefo
Post by karlefo »
Thanks for help.
The issue has been fixed.
I placed a copy of *.ice file (same file placed on flexlm server) on Opentouch folder: /var/data/license, but it seems that in OpenTouch R 2.0.1, the file alchostid.cfg is filled automatically by the OpenTouch when the services are restarted.
Best regards
Return to “OTMS - OpenTouch Multimedia Services”
