OMC Command Line
- giovanni.attolini
OMC Command Line
I know that omc.exe can be launched with some parameters like /IP=OXOIPAddress. Is there a doc that show all available parameters? Anybody knows about these omc command line parameters?
thanks
thanks
Giovanni A. Attolini
- giovanni.attolini
Re: OMC Command Line
I discovered some parameters here using a disassembler.
For example, a simple IP connection:
omc.exe /STANDALONEMODE /IP=OXOIPAddress /PASSWORD=InstallerPassword
Now I need to know how to include port info in case of NAT. I tested ":port" after IP address but not working this way.
O.o seems you have a lot of free time hehe
Thanks for sharing
Enviado de meu C6602 usando Tapatalk
Thanks for sharing
- giovanni.attolini
heheh... yes, a lot of free time...
Cavagnaro, yes, I tried but it doesn't accept this syntaxe.
To tell omc.exe the Port of the oxo xmlsrv you need to use the following switches:
omc.exe /IP_PBX=<your_oxo_ip_address:yourport /password=<your_installer_pw>
for example:
for example:
omc.exe /IP_PBX=192.168.92.246:50443 /password=omcwoodoo- giovanni.attolini
It's working... Thanks...
Have you docs about omc command line?
Hi Giovanni,
sorry I don't have any special omc documentation. The command line options are from AST 2.3.0.1 (alcatel save tool). AST invokes omc.exe with parameters to save batches of system configs.
- giovanni.attolini
Ok, I will look for this parameters here.
Thanks fe80!
Thanks fe80!
Demonslayer4000
I just wanted to say Thank you this works really wellfe80 wrote: ↑16 Sep 2015 07:35 To tell omc.exe the Port of the oxo xmlsrv you need to use the following switches:
for example:Code: Select all
OXO ACSE | OXO Trainer
Omniswitch ACFE
OXE ACSE
Omniswitch ACFE
OXE ACSE
