[ASK] PING From 7210 to 7750 with size count Drop Packet
thekotaksampah
Post by thekotaksampah »
Hallo everyone,
I using OSPF for IGP, then I try to ping system address. and something happened like this
|7210|---------------ospf--------------------|7750|
A:Lab_7210_SASM# ping 10.10.10.10 rapid count 1000 size 1460
PING 10.10.10.10 1460 data bytes
---- 10.10.10.10 PING Statistics ----
1000 packets transmitted, 914 packets received, 8.60% packet loss
round-trip min = 2.71ms, avg = 5.06ms, max = 68.8ms, stddev = 6.56ms
A:PE2-POC-DNS-ISAT# ping 21.21.21.21 rapid count 1000 size 1460
PING 21.21.21.21 1460 data bytes
---- 21.21.21.21 PING Statistics ----
1000 packets transmitted, 435 packets received, 56.50% packet loss
round-trip min = 2.63ms, avg = 7.24ms, max = 85.6ms, stddev = 12.5ms
Is there any limitation from 7210? Ore anything problem?
Technical Blog: ngoprek.achyarnurandi.id
thekotaksampah
Re: [ASK] PING From 7210 to 7750 with size count Drop Packet
thekotaksampah wrote:Hallo everyone,
Update My SASM in area 1 ospf, then I ping to other router in other area across area 0. But when in single area, there is no packet dropp count.
thecandymancan
Post by thecandymancan »
There should be no correlation between OSPF and pings. Can you post configs? Control plane policing on the 7750? CPM queuing?
Because the rapid command sends so fast, and the timeout is much longer than a normal response, the sequence of . vs ! is not accurate. Your 1st !.! could well be one of the 1st pings but it reports it occurring much later.
thekotaksampah
hy thecandymancan,
Thanks for your help, i found known limitation about ping in 7210 OS Release notes.
Maybe it can be problem issue :)
Return to “7210 SAS”
