View/Change the password 4635 Voicemail
isurud
Post by isurud »
Hi Guys,
I am a newbie to Alcatel.
May I know, how to view/change voicemail PIN/password for 4635 type voicemail using MGR ?
The PBX we are using is Alcatel OmniPCX Enterprise 4400. Any help is highly appreciated.
Re: View/Change the password 4635 Voicemail
I think - this is impossible. You can delete VM from user parameters and create again - but user will need to initialize VM box from the beginning (name, password, greeting etc).
Usually user can change password himself. If user forgot password - from my point of view the best way - connect to 4635 via console port and edit VM box parameters in 4635 (manage temporary password).
Return to “Voicemail (46x5)”
