I have an Alcatel OXO system and i have a problem in My ic web office when i dialed ext. no. then error msg showing The dialed number is invalid
plz somebody help me .
My IC Web office in oxo
jp choudhary
- Konstantinos.E
Re: My IC Web office in oxo
hello..
can you dial an Internal Number? if yes call the company that supports this pbx to define outgoing rules...
Alca_holic
jp choudhary
what kind of outgoing rules i am little aware about alcatle OXO and OMC plz suggest me how to do that .............
- Konstantinos.E
hi
it is imposible to know your configuration if you dont post it.
ARS? trafic sharing?barring?numbering plan? what should i suggest you?. Thats why i told you to contact an Alcatel partner..
but you did not answer ...can you make an Internal call?
Alca_holic
