OXE in Multi Countries
Ask your questions, regarding data or voice!
Tenna
Post by Tenna »
Hello guys
I want to run OXE in 4 Countries.
1. Can we run Multi-Country
2. Does this mean that each of these countries needs to have a good VPN connection between each other.
3. Can we run the OXEs, single node only with Media Gateways across all the countries and then monitor using single Omni Vista.
4. Is there any risk with respect to security when we run the Multi-Country.
Re: OXE in Multi Countries
Tenna wrote:Hello guys
[b]yes but oxe with release 9.0 minimum"As of R9.0, the Multi-Country feature allows an Alcatel-Lucent OmniPCX Enterprise CS to support configurations where the sites of a node are in different countries."[/b]
2. Does this mean that each of these countries needs to have a good VPN connection between each other. not necessary but a good vpn connection with the call server
yes one call server with media gateways across all coutrie , single oxe can be crystal or common Hdwre , but Mediagtw mandatory common hdw
yes single omnivista
4. Is there any risk with respect to security when we run the Multi-Country.When the IP Touch Security service is required, all the countries of the system must legally allow the use of this service
see system doc for more detail how to config and feature restrictions
Tenna
Post by Tenna »
Thanks a lot haroun
Just on 2, on the VPN connection, for the signalling between the CS and the Mediagtw, and also the traffic flow if the call is made between different countries, would VPN be a recommended option. I am thinking that international private circuits would be too expensive. Anything about the VPN we have to be careful. Please let us know.
Return to “Pre-Sales”
