HOW TO RETREIVE A DELETED VOICEMAIL MESSAGE .
melozurdo
Hi guys,
Is there any option to retreive a deleted voicemail message?. An user from my customer accidentally deleted a voicemail message and wants to retreive it. Voicemail system is 4635.
Thanks in advance.
Nacho
Thanks in advance.
Nacho
Re: HOW TO RETREIVE A DELETED VOICEMAIL MESSAGE .
i think there is no chance to do this...
regards...
regards...
melozurdo
Anyone else think the same? I would like to have more than one response before informing my user.
If you did. Backup then you can maybe restore. If not, as last year's pictures from your party that were deleted from your cellphone, they are gone for good
melozurdo
cavagnaro wrote:If you did. Backup then you can maybe restore. If not, as last year's pictures from your party that were deleted from your cellphone, they are gone for good
when you said "if you did backup" you mean, I did backup for 4635 general system? If this is the question, I didnt .
Or you mean I did a backup for an specific voice mailbox?
Nacho
Any of them...as said, no backup then you are done. I doubt that if you had a backup of specific voice mail you would have opened this thread
melozurdo
Maybe I have a backup and I don´t know...how to check if a backup for 4635 voicemail is done automatically? Or it´s something that have to do manually?cavagnaro wrote:Any of them...as said, no backup then you are done. I doubt that if you had a backup of specific voice mail you would have opened this thread
Nacho
Of course is manually as part of your contingency plan.
melozurdo
Ok...well...can you please show me how to do this? Can you please write me down the steps?cavagnaro wrote:Of course is manually as part of your contingency plan.
I am not really sure if I´m reponsible to do this task in my project but just in case.
Nacho
google is your friend
viewtopic.php?t=11974&start=10
but i think, it's much effort for one voicemessage (but maybe the content of the message is very important...)
regards...
regards...
