CPU 7_2 IP Management issue
marius30
Post by marius30 »
I try to find the ip address from my VPU5 card....during this I made a mistake and please I need some help to repair this.
My 4400 have two CPU7_2 both working with management network from 4760 server.
I opened swinst menu on easy menu nr 9 Set new internet address .....and I just follow the step:
- Enter Ip addres from CPU( default is 192.168.0.2) I just push enter
- enter mask ( default is 255.255.255.0) again enter
- IP address PC A4740( default is 192.168.0.223) again I push enter
- confirm ? y/n ( default is Y) again enter
After that I lose the management for that CPU, I restart the CPU ...nothing hapened.
I appreciate any help to solve this issue
Many thanks
Re: CPU 7_2 IP Management issue
You should first build a lab (Vmware is your friend) and accommodate with the system and then touch production systems.
Check the system documentation --> maybe your system is secured or was secured, maybe you are working with trusted hosts...we cannot guess.
sadim
Post by sadim »
You need to restore the netadmin configuration.
To do that you need to execute:
netadmin -m
then you must select the option History of last actions
then restore the proper one
marius30
Post by marius30 »
I back from history and right now I have ping reply from that CPU.
Many thanks Sadim
Return to “Swinst”
