OSPF Configuration in 6850E
garga
Hi everyone.
How can configur OSPF between two 6850E,
I need full configuration.
Software in switch 6.4.6
Can we configure EIGRP in Alcatel 6580E ?
Thanks in advance.
Garga
Thanks in advance.
Garga
devnull
Re: OSPF Configuration in 6850E
please have a look in the manuals.
There is a quick Start part in the advanced routing with an example, which covers the basic needed configuration for ospf.
EIGRP was cisco propitary and has opened afaik in the last years(s) but i don not know of any other vendor who implemented it - so no luck with alu
garga
i config and its still take all routes from Eigrp,means when i traceroute its go to internet tho old Eigrp route not go tho OSPf.
it there any commad for priority to alcatel switch choose ospf not eigrp
garga
one problem,or can say one question, i config all things and alcatel show all routes form LAN which come form Cisco router Eigrp but still higher priority to Cisco router which is 100mb
we like its give priority to alcatel ospf route which 1Gbit link ,and only use old link when 1Gbit down. cisco router use static redistribute.
devnull
default administrativ distance for OSPF is 110 for eigrp it is 90 -> eigrp is better.
You can fiddle with the paramters e.g. http://www.cisco.com/c/en/us/support/do ... 73-14.html
-> have a lab, plan a downtime
garga
thanks
yes know about AD, but how i can change to its use OSPF Protocol for Routing
devnull
Great.. care to give an solution?
Future visitors that have the same issue would be thankful
