Alcatel Lucent 4038 IP Touch and Switch
Messiah Alcatel
I'd like to connect an Alcatel Lucent 4038 IP Touch using a Switch to a LAN Port. When I connect the telefon directly to the port the telefon starts up, if i use the switch it does not start up; do i have to specify s.th so that i can use the switch? Or ist it not possible to interconnect a switch?
It is neede, becaus I like to use to phones on the same LAN-Port b/c all others are already occupied.
Re: Alcatel Lucent 4038 IP Touch and Switch
Connect directly - to the LANX board or another places?
Messiah Alcatel
If i connect the telephone directly to the port it works, i tried also two different switches, with the switches a computer can used, it's only the telephone which is making trouble
I also tried different telephones; to me it seems either impossbile by how the hardwre has been constructed or I forgot sth
- tot3nkopf
Are you using a dedicated VLAN fo voice? Is the VLAN configured on all switch ports?
Are you doing a cascade without a power supply? Is that it? main switch is PoE enabled and the second one isn't? Am I understanding that right? "Understanding" as you don't mention anything clearly actually...guessing is the word.
If your new switch doesn't provide energy via Ethernet it won't boot
How? Like share knowledge as you were also requesting it?
Messiah Alcatel
In the end it was truly a power problem. The switched i used should support 802.3at, but i didn't. Using a different power device and the problem was solved.
Great thanks for sharing
Good luck!
Good luck!
halleluja...... lol of corse
