hi,
I am connecting a grand stream phone GXV3275 on my oxe, which is in release 10.0.
when configured the phone as SIP device incoming call are ok. but outgoing call get disconnect in 4 seconds after answering.
in Trunk COS category 31 the default value for timer T313 is 40. and this is why call is getting disconnected after 4 second. But when I increase the timer the call disconnect after the timer value is reached.
SIP device call disconnect
Re: SIP device call disconnect
Logs and search the forum
hi,
I have searched the forum could find anything that can help me on this issue.
below is the motortrace file taken from a call made fromm extension 666 (SIP device) to 888 (IP 4038)
traced started ...
1450161513 -> cl_daCalendar::dayOfWeek
1450161516 -> cl_daCalendar::dayOfWeek
1450161517 -> cl_daCalendar::dayOfWeek
1450161517 -> Tue Dec 15 11:38:37 2015 RECEIVE MESSAGE FROM NETWORK (192.168.124.21:5060 [UDP])
INVITE sip:888@192.168.10.202 SIP/2.0
Via: SIP/2.0/UDP 192.168.124.21:5060;branch=z9hG4bK1408375075;rport
To: <sip:888@192.168.10.202>
Call-ID: 1670732117-5060-17@BJC.BGI.BCE.CB
CSeq: 160 INVITE
Contact: <sip:666@192.168.124.21:5060>
Max-Forwards: 70
User-Agent: Grandstream GXV3240 1.0.3.46
Privacy: none
P-Preferred-Identity: <sip:666@192.168.10.202>
Supported: replaces, path, timer, eventlist
Allow: INVITE, ACK, OPTIONS, CANCEL, BYE, SUBSCRIBE, NOTIFY, INFO, REFER, UPDATE, MESSAGE
Content-Type: application/sdp
Accept: application/sdp, application/dtmf-relay
Content-Length: 262
v=0
o=666 8000 8000 IN IP4 192.168.124.21
s=SIP Call
c=IN IP4 192.168.124.21
t=0 0
m=audio 5004 RTP/AVP 0 8 9 101
a=sendrecv
a=rtpmap:0 PCMU/8000
a=ptime:20
a=rtpmap:8 PCMA/8000
a=rtpmap:9 G722/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
ø-------------------------------------------------
Tue Dec 15 11:38:37 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 277)
SIP/2.0 100 Trying
CSeq: 160 INVITE
Via: SIP/2.0/UDP 192.168.124.21:5060;received=192.168.124.21;branch=z9hG4bK1408375075;rport=5060
Content-Length: 0
1450161517 -> Tue Dec 15 11:38:37 2015 [display_ipc_out] ------------ Begin ---------------
Tue Dec 15 11:38:37 2015 Id : -1
Tue Dec 15 11:38:37 2015 INVITE
Tue Dec 15 11:38:37 2015 REQUEST URI : <> 888@192.168.10.202:5060 ; user=name
Tue Dec 15 11:38:37 2015 FROM : <> 666@192.168.10.202:5060 ; user=name
Tue Dec 15 11:38:37 2015 TO : <> 888@192.168.10.202:5060 ; user=name
Tue Dec 15 11:38:37 2015 CAC : 0
Tue Dec 15 11:38:37 2015 CAC ADDRESS :
Tue Dec 15 11:38:37 2015 CAC-CSBU info : UNKNOWN
Tue Dec 15 11:38:37 2015 CLIR : 0
Tue Dec 15 11:38:37 2015 Prack Required : 0
Tue Dec 15 11:38:37 2015 Allow Update : 0
Tue Dec 15 11:38:37 2015 SDP :
Tue Dec 15 11:38:37 2015 ADDRESS : 192.168.124.21 :5004
Tue Dec 15 11:38:37 2015 ALGOS :
Tue Dec 15 11:38:37 2015 PCMA
Tue Dec 15 11:38:37 2015 G722
Tue Dec 15 11:38:37 2015 101
Tue Dec 15 11:38:37 2015 DIRECTION : SEND & RECEIVE
Tue Dec 15 11:38:37 2015 crypto index : 0
Tue Dec 15 11:38:37 2015 N_GW_EXT : -1
Tue Dec 15 11:38:37 2015 [display_ipc_out] ------------- End ----------------
Tue Dec 15 11:38:37 2015 11fa[CMotorCall::setCurrentState] NOE-SIP : sendBackupUpdate Msg not sent to twin CS
Tue Dec 15 11:38:37 2015 [display_ipc_in] ------------ Begin ---------------
Tue Dec 15 11:38:37 2015 neqt : 4607 Id : -1
Tue Dec 15 11:38:37 2015 INFORMATIONAL
Tue Dec 15 11:38:37 2015 xx : 80
Tue Dec 15 11:38:37 2015 RELATIVE REQUEST : INVITE
Tue Dec 15 11:38:37 2015 [display_ipc_in] ------------- End ----------------
Tue Dec 15 11:38:37 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 471)
SIP/2.0 180 Ringing
Allow: INVITE, ACK, CANCEL, BYE, PRACK, NOTIFY, REFER, SUBSCRIBE, OPTIONS, UPDATE
Contact: sip:node000000
User-Agent: OmniPCX Enterprise R10.0 j1.410.34
To: <sip:888@192.168.10.202>;tag=f2cd69831c9cb71fa1bd54297e71817a
CSeq: 160 INVITE
Content-Length: 0
1450161521 -> Tue Dec 15 11:38:41 2015 RECEIVE MESSAGE FROM NETWORK (192.168.124.21:5060 [UDP])
Tue Dec 15 11:38:41 2015 [CIOCom::onReceiveMessage] Message is incomplete
Tue Dec 15 11:38:41 2015 [CIOCom::getMalformedMessage]
Tue Dec 15 11:38:41 2015 [display_ipc_in] ------------ Begin ---------------
Tue Dec 15 11:38:41 2015 neqt : 4607 Id : -1
Tue Dec 15 11:38:41 2015 SUCCESSFUL
Tue Dec 15 11:38:41 2015 xx : 0
Tue Dec 15 11:38:41 2015 RELATIVE REQUEST : INVITE
Tue Dec 15 11:38:41 2015 CLIR : 0
Tue Dec 15 11:38:41 2015 COLP : 1
Tue Dec 15 11:38:41 2015 CAC-CSBU info : UNKNOWN
Tue Dec 15 11:38:41 2015 SDP :
Tue Dec 15 11:38:41 2015 ADDRESS : 192.168.100.131 :32002
Tue Dec 15 11:38:41 2015 ALGOS :
Tue Dec 15 11:38:41 2015 PCMA
Tue Dec 15 11:38:41 2015 101
Tue Dec 15 11:38:41 2015 DIRECTION : SEND & RECEIVE
Tue Dec 15 11:38:41 2015 crypto index : 0
Tue Dec 15 11:38:41 2015 [display_ipc_in] ------------- End ----------------
Tue Dec 15 11:38:41 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 861)
SIP/2.0 200 OK
Supported: replaces,timer,100rel
Session-Expires: 1800;refresher=uas
P-Asserted-Identity: "Aris 888" <sip:888@node000000;user=phone>
CSeq: 160 INVITE
Content-Length: 221
v=0
o=OXE 1450161517 1450161517 IN IP4 192.168.10.202
s=abs
c=IN IP4 192.168.100.131
t=0 0
m=audio 32002 RTP/AVP 8 101
a=sendrecv
a=ptime:20
a=maxptime:30
یK)-------------------------------------------------
1450161523 -> Tue Dec 15 11:38:42 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 861)
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
Tue Dec 15 11:38:43 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 861)
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
1450161525 -> Tue Dec 15 11:38:44 2015 RECEIVE MESSAGE FROM NETWORK (192.168.124.249:5064 [UDP])
Tue Dec 15 11:38:44 2015 [CIOCom::onReceiveMessage] Message is incomplete
Tue Dec 15 11:38:44 2015 [CIOCom::getMalformedMessage]
Tue Dec 15 11:38:45 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 861)
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
Tue Dec 15 11:38:45 2015 [display_ipc_in] ------------ Begin ---------------
Tue Dec 15 11:38:45 2015 neqt : 4607 Id : -1
Tue Dec 15 11:38:45 2015 BYE
1450161525 -> Tue Dec 15 11:38:45 2015 [display_ipc_in] ------------- End ----------------
Tue Dec 15 11:38:45 2015 SEND MESSAGE TO NETWORK (192.168.124.21:5060 [UDP]) (BUFF LEN = 422)
BYE sip:666@192.168.124.21:5060 SIP/2.0
To: sip:666@192.168.10.202;tag=672871558
From: sip:888@192.168.10.202;tag=f2cd69831c9cb71fa1bd54297e71817a
CSeq: 1846428010 BYE
Via: SIP/2.0/UDP 192.168.10.202;branch=z9hG4bK3a7008db0e60ee66cfe50a1fdab300e1
Max-Forwards: 70
Content-Length: 0
24.)-------------------------------------------------
Tue Dec 15 11:38:45 2015 RECEIVE MESSAGE FROM NETWORK (192.168.124.21:5060 [UDP])
SIP/2.0 200 OK
From: <sip:888@192.168.10.202>;tag=f2cd69831c9cb71fa1bd54297e71817a
To: <sip:666@192.168.10.202>;tag=672871558
Content-Length: 0
Tue Dec 15 11:38:45 2015 [display_ipc_out] ------------ Begin ---------------
Tue Dec 15 11:38:45 2015 Id : -1
1450161526 -> EAu: Block Memory Size: 151520
1450161526 -> EAu: Dupli window: 0/1 (max: 0)
1450161529 -> Tue Dec 15 11:38:45 2015 SUCCESSFUL
Tue Dec 15 11:38:45 2015 xx : 0
Tue Dec 15 11:38:45 2015 RELATIVE REQUEST : BYE
Tue Dec 15 11:38:45 2015 CAC-CSBU info : UNKNOWN
Tue Dec 15 11:38:45 2015 CLIR : 0
Tue Dec 15 11:38:45 2015 COLP : 0
Tue Dec 15 11:38:45 2015 [display_ipc_out] ------------- End ----------------
Tue Dec 15 11:38:45 2015 SIP EQT RELEASED
Tue Dec 15 11:38:45 2015 SIP_EQT_RELEASE_ACK
traced started ...
CSeq: 160 INVITE
Max-Forwards: 70
Privacy: none
Content-Length: 262
v=0
s=SIP Call
t=0 0
a=sendrecv
a=ptime:20
a=fmtp:101 0-15
SIP/2.0 100 Trying
CSeq: 160 INVITE
Content-Length: 0
SIP/2.0 180 Ringing
CSeq: 160 INVITE
Content-Length: 0
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
SIP/2.0 200 OK
CSeq: 160 INVITE
Content-Length: 221
v=0
s=abs
t=0 0
a=sendrecv
a=ptime:20
a=maxptime:30
Max-Forwards: 70
Content-Length: 0
SIP/2.0 200 OK
Content-Length: 0
There is not ACK to the OK SIP msg. Rather then ACK, i can see "Message is incomplete". A wireshark capture will be nice to check what is the problem.
this happens when extension is configured as SIP device. Extensions which are configured as SIP extensions are working fine. So I think it can be a problem with SIP trunk group or some timer setting. if anyone has experienced this please share your resolution.
