Update Otms 2.1 to 2.1.1 failed
Split
Today i try a update omts-v 2.1.0.101 to otms-v 2.1.1 i did not expect any problems because the minimal release jump but it is not working .....the chameleon service is Not starting i check "service chameleond status" and the result is the service stays at starting not started after a while the service is terminated and start again.
I check logs and it seems something with java. With top i can see a process 130% cpu usage for short time. I restore a Backup of the virtuell Maschine and try again but it happens again i have no idea whats the reason for that.
I will Check Logs tomorrow cause there are so many logs it takes a lot time but if i found something i will post ot here
Have somebody a idea whats the chameleon service starts or give mehr a hint how i solve this?
Thanks for Held
Split
Thanks for Held
Split
Re: Update Otms 2.1 to 2.1.1 failed
i had no problems some. updated last week an ot from 2.1 to 2.1.1 physical installation. update was done with 2nd partition.
regards...
regards...
Split
Hi tgn
My otms is in a vmware esxi 5.5.
After the update the first i see is that the Service that restarting
Now i spent a lot of time ...in the logs iam unable to find something at the moment. But whats real strange is that 8770 unable to connect to EES ; the global synchronisation works only for oxe. I can connect to the WBM from 8770 but a connect to the Teamwork ACS Server fails with invalid authentification or expired message ....conference and mailbox are reachable but all 8082 cant connect to EES i update the 8082 to the new Binary Version x.12 like discribe in tc. A update on 2nd partiton not possible in virtualisation.
Im very confused
Im very confused
So a question i know they have had issues before, check the firewall on the OT server in redhat !!!! i think as part of an upgrade that is turned on turn it off and see how it goes
Split
Hi oldboy
I checked the firewall but this is disable.... before i start the update i run a systenCheckLinux.sh from the ot2.1.1 dvd and all was ok after the update i do this again and all seems ok but it isnt
Have you updated the licence server as well??
Split
Yes to the new one wich supports esxi 5.5 and have the rasperry pi Image included ...checkLicencse.sh says all ok
what says the output of ifconfig?
regards...
regards...
Split
Hi thanks for Help
@tgn
[root@otms01 otuser]# ifconfig
br0 Link encap:Ethernet HWaddr 00:0C:29:70:8D:61
inet addr:192.168.99.18 Bcast:192.168.99.255 Mask:255.255.255.0
inet6 addr: fe80::20c:29ff:fe70:8d61/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:247800 errors:0 dropped:0 overruns:0 frame:0
TX packets:266796 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:58921599 (56.1 MiB) TX bytes:91491381 (87.2 MiB)
eth0 Link encap:Ethernet HWaddr 00:0C:29:70:8D:61
RX packets:252278 errors:0 dropped:0 overruns:0 frame:0
TX packets:266805 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:62643039 (59.7 MiB) TX bytes:91492339 (87.2 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:7746057 errors:0 dropped:0 overruns:0 frame:0
TX packets:7746057 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1420045525 (1.3 GiB) TX bytes:1420045525 (1.3 GiB)
did you mean this?
@tgn
did you mean this?
Split
Late feedback. ..
I didnt find the reason so install R2.1.1 from scratch all service running restore backup and it happens again so i export user data from otms restore the backup which made at first start and Import User data and fill the other things like unified messaging so now ist working ..
Late feedback. ..
