lldp config on 6850
mike18
lldp config on 6850
Post by mike18 »
Hi Everyone,
What does below config do
lldp 1/7 tlv med network-policy enable
lldp 1/7 med network-policy 1
Mike
Re: lldp config on 6850
there must be a lldp med network policy 1 f.e. for phones. You can check with show configuration snapshot lldp.
lldp network-policy 1 application voice vlan 2242 dscp 46
If now is at port 1/7 an ip-phone attached that is also speaking lldp med, than the switch tells the phone via lldp to 802.1q-tag with vlan 2242 and prio all voip packets with dscp 46.
mike18
Post by mike18 »
Hi Silvio,
Yes there is config
lldp network-policy 1 application voice vlan 224 2 l2-priority 5 dscp 46
What does this network policy do if you can explain me in detail that will be greatly appreciated.
Happy Holidays
Mike
like descriped in my last post:
is there an lldp-enabled phone attached to the port with the assiciated policy than the switch triggered the phone to 802.1q-tag with the vlan f.e. 2242 (and also to activate QoS).
johnsheco
Post by johnsheco »
MON OCT 10 09:31:15 2016 LLDP warning [Count.]Port 1/10
MON OCT 10 09:31:17 2016 LLDP warning lldpProcessInventoryTLV: Warning, MED Capabilities TLV is not first MED TLV on
MON OCT 10 09:31:17 2016 LLDP warning [Count.]Port 1/9
MON OCT 10 09:31:26 2016 LLDP warning lldpProcessInventoryTLV: Warning, MED Capabilities TLV is not first MED TLV on
MON OCT 10 09:31:26 2016 LLDP warning [Count.]Port 1/10
MON OCT 10 09:31:28 2016 LLDP warning lldpProcessInventoryTLV: Warning, MED Capabilities TLV is not first MED TLV on
