Omnitouch 8128 service needed
iVomera
Post by iVomera »
Hello All,
I have a question. After unboxing the alcatel omni touch 8128 and synced with winpdm everything looks fine. Installed template, upgraded the software. Device was ready for use and asking for his number. So i shutdown the device and didnt use the phone for a few weeks. Now i have to use it again but if i power on the device it says "Service needed" (normally in dutch) and reboots after 20/30 seconds. I synced with Winpdm again no solution, so i tried to upload the software again. He reboots and i see the language is in english again but still the message "Service needed". Tried also another template but no solution either. Does some have a solution for this problem?
Konstantinos.E
Re: Omnitouch 8128 service needed
Post by Konstantinos.E »
hello
Go to admin interface and make a factory reset.
Alca_holic
iVomera
Post by iVomera »
Tried that already but still same message.. Back to supplier ?
So it will be the onliest chance - make support (RTF) for this phone.
manoj
Post by manoj »
Hi iVomera,
Have you succeeded to find out the problem..
I am also facing same issue on 8128 phone.Showing "Service Needed"
Manoj
Return to “Mobile IPTouch Phones (MIPT)”
