Change all connected IP sets mode to Alcatel Dynamic
Maulwurf
Post by Maulwurf »
Hi all,
found at BPWS script to change static IP sets to dynamic. The attached script will change all the connected IPT mode to Alcatel Dynamic.
In my lab (OXE VMware 11.2-l2.300-25-c-de-c0) i get the following error:
(1)xa000000>
(1)xa000000> cd /tmpd
(1)xa000000> chmod 777 iptouch_dhcp.sh
(1)xa000000> chmod 777 all_iptouch_dhcp.sh
(1)xa000000> ./all_iptouch_dhcp.sh
-- Auto Script
-- Copyright 2014. Alcatel-Lucent Technical Support
Reading the list of IPtouch phones...
/tmpd/iptouch_dhcp.sh: line 1: IPv4: command not found
...: Unknown server error
/tmpd/iptouch_dhcp.sh: line 42: return: ...: numeric argument required
.........: Unknown server error
Task Finished.
Wed Mar 9 09:09:22 CET 2016
(1)xa000000>
Can you help me to solve this?
sadim
Re: Change all connected IP sets mode to Alcatel Dynamic
Post by sadim »
Please attach both shell files (iptouch_dhcp.sh and all_iptouch_dhcp.sh)
Maulwurf
Post by Maulwurf »
Here are the files
sadim
Post by sadim »
Check the contentes of the file /tmpd/listipt
Maulwurf
Post by Maulwurf »
Hi sadim,
that my listipt:
|100 |RH1 |00:80:9f:88:1e:7c |S|02100| IPv4 | 192.168.100.176| Unused| Ipt| GE| - |
|102 |RH3 |00:80:9f:a4:07:c8 |S|02128| IPv4 | 192.168.100.175| Unused| Ipt| GE| - |
Both IP Phones have static IP.
sadim
Post by sadim »
The Shell script is OXE version dependent. You need to replace the contents of the file iptouch_dhcp.sh with:
#!/bin/bash
# THIS SCRIPT IS DESIGNED FOR setting dhcp to alcatel dynamic
# Copyright 2014. Alcatel-Lucent Technical Support
# INPUT PARAMETERS VERIFICATION
echo
echo \-\- Auto Script for setting iptouch dhcp to alcatel dynamic
echo \-\- Copyright 2014. Alcatel-Lucent Technical Support
echo
echo `/bin/date`
echo
while read LINE
do
# GET EXTENSION NUMBER & IP INFORMATION
LINE="${LINE//[[:space:]]/}"
eval `echo $LINE|awk -F "|" '{print "EXT="$2}'`
eval `echo $LINE|awk -F "|" '{print "IP="$8}'`
# SPLIT IP TO 4 PARTS
IP1=${IP:0:3}
IP2=${IP:4:3}
IP3=${IP:8:3}
IP4=${IP:(-3)}
# REMOVE ADDITIONAL ZEROS FROM IP ADDRESS
function remzero {
local INPUT=$1
if [ ${#INPUT} -ge 1 ]
then
if [ ${INPUT:0:1} = "0" ]
then
INPUT=${INPUT:1:2}
remzero $INPUT
INPUT=$rtn
fi
fi
rtn=$INPUT
return $rtn;
remzero $IP1
IP1=$rtn
remzero $IP2
IP2=$rtn
remzero $IP3
IP3=$rtn
remzero $IP4
IP4=$rtn
IP=$IP1.$IP2.$IP3.$IP4
#PROCESS THE CONFIGURATION CHANGE
echo Enabling Telnet Service for IP address $IP Extension $EXT ...
echo `/usr2/oneshot/mtcl/tool ippstat telnet d $EXT t 1440`
echo
sleep 5
echo Setting config boot information from $IP Extension $EXT ...
echo `(sleep 2;echo "config dhcp a";sleep 2; echo "reset";sleep 2) | /usr/bin/te
lnet $IP`
echo
echo
echo done.
sleep 2
echo
done < $1
#TASK FINISHED INDICATION
echo
echo Task Finished.
echo `/bin/date`
sadim
Post by sadim »
You can replace your iptouch_dhcp.sh file by the one in attach
iptouch_dhcp.zip
Maulwurf
Post by Maulwurf »
Hi sadim,
thank you very much for helping me. That is great.
With your new "iptouch_dhcp.sh" it works in my lab. I see you added... LINE="${LINE//[[:space:]]/}"
Can you explain why i need this? I will understand it. Original file from BPWS knowledge center should work with OXE R 10 and R11.
Find file and description at BPWS knowledge center. Search "000013045"
sadim
Post by sadim »
I added that in order to remove the spaces of on each entry of the file listipt and with this small change i did not need to change the rest of the script (except the line: eval `echo $LINE|awk -F "|" '{print "IP="$7}'` that i also had to change to eval `echo $LINE|awk -F "|" '{print "IP="$8}'`)
tgn
Post by tgn »
good inspirarion for some other scripts. didn't found this script before on bwps.
thanks for share
regards...
Return to “DHCP Configuration”
