The license for my omnivista 4760 is Release 3.0.15. I have hardware issue on my server and i have to reinstall it. The only version which is available from partner portal is Rel. 5.2.
Can I use my current license for release 5.2
Information for license 4760
doublezero
Re: Information for license 4760
No i think you can use 4.0. 4760 license is valid for 3.0 and next relase. I have to check which one that is, i belive it is 4.0. maybe i have a valid relase i will check it tommorow
Gesendet von meinem A0001 mit Tapatalk
Zero
Hi opencom,
As reference on OV4760 license version compatibility for its installer releases, please see list below:
OV4760 R3.0 = license version 5;
OV4760 R3.1 = license version 6;
OV4760 R3.2 = license version 7;
OV4760 R4.0 = license version 8;
OV4760 R4.1 = license version 9;
OV4760 R4.2 = license version 10;
OV4760 R5.0 = license version 11;
OV4760 R5.1 = license version 12; and
OV4760 R5.2 = license version 13
Meanwhile, you can use a different license version based on the authorized licenses as:
authorize licenses for OV4760 R3.0 = license version 4 & 5;
authorize licenses for OV4760 R3.1 = license version 5 & 6;
authorize licenses for OV4760 R3.2 = license version 5, 6 & 7;
authorize licenses for OV4760 R4.0 = license version 7 & 8;
authorize licenses for OV4760 R4.1 = license version 8 & 9;
authorize licenses for OV4760 R4.2 = license version 9 & 10;
authorize licenses for OV4760 R5.0 = license version 10 & 11;
authorize licenses for OV4760 R5.1 = license version 11 & 12; and
authorize licenses for OV4760 R5.2 = license version 12 & 13
From your query, you can not utilize your OV4760 R3.0 license file to install a R5.2.
Thanks and regards,
Zero
Thanks and regards,
Zero
doublezero
Okay there was a relase 3.1 and 3.2 between.
I have releases
3.0.16
3.1.07
3.2.04
I have releases
3.0.16
3.1.07
3.2.04
