6850E Port Security Issue
dmendj
Post by dmendj »
Hi Experts,
I am having a problem with my network. I have 6850E stack with two switches. I have a several Linux servers. The servers have 2 links connected to the stack (switch 1 and 2). I need to enabled port security so I have done below..
port-security shutdown 10 learn-as-static enable no-aging enable
port-security 1/33 admin-status enable
port-security 1/33 maximum 2
port-security 1/33 max-filtering 0
port-security 1/33 violation shutdown
port-security 2/33 admin-status enable
port-security 2/33 maximum 2
port-security 2/33 max-filtering 0
port-security 2/33 violation shutdown
I have dine the same to all other ports as well. but once port-security enabled I am getting timeouts on my network. I have not created Linkagg on those ports. Any idea.... For NIC teaming do I need to create LACP or static LAG ???
Re: 6850E Port Security Issue
mostly no linkagg is the best solution - the server decides how to handle the traffic.
lacp needs the same 802.3ad also at the server. You can try with static lag - but I haven't seen succesfull installation to servers with it.
You can also try to deactivate lps at this both ports for a time to see the difference.
sitig
Post by sitig »
Port Security is not supported on Link aggregate ports......
Every adversity has within it a seed of an equivalent or greater benefit....
