Some IP touch 4028/38 not working tftp no response
jgaadesh
Post by jgaadesh »
After upgrade from R11.2 l.230020.e to l.230025.c some IP touch 4028 & 38 sets are not working.
Below are the tftp_check snaps:
(1)cortbgpbx002> tftp_check -n 3786
Fri Apr 8 11:55:28 CEST 2016
Terminal state : OUT OF SERVICE
Terminal type : IPTOUCH B EE Gigabit
Terminal segment versions are :
Bootloader : 0.00.00
Code : 4.33.40
Data : 4.33.40
SIP : Unknown
Terminal localization file : none
Terminal customization file : none
For this Terminal, call server versions are :
Bootloader : 4.34.00
Code : 4.34.00
Data : 4.34.00
SIP : 2.12.40
Terminal tftp state is : UPDATE EVALUATION REQUESTED
Current update action : BOOTLOADER + CODE + DATA
Download not allowed cause : DENY OF DOWNLOAD
(1)cortbgpbx002> tftp_check -n 3713
Fri Apr 8 11:56:04 CEST 2016
Terminal type : IPTOUCH C
Bootloader : Unknown
Code : Unknown
Data : Unknown
Bootloader : 4.33.40
Code : 4.33.40
Data : 4.33.40
Terminal tftp state is : IDLE
Current update action :NONE
Looks like some sets are unable to take new binary version...
Re: Some IP touch 4028/38 not working tftp no response
Can be a network issue where those phones are trying to download the new binary and just can't. Check for delay or try to discard by avoiding many jumps.
jgaadesh
Post by jgaadesh »
Other phones are working fine on same port. Can't be a network issue... No delay response in tftp server ping
murraya
Post by murraya »
maybe check the working vs not working phone settings for things like is lldp enabled differently, is vlan enabled differently.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
jgaadesh
Post by jgaadesh »
Before upgrade sets are working fine no such changes..
Can you please check? The sentence it was working and nothing before we already know it and just because we ask to check even baby steps as are many times overseen and discarded but can actually be the root of your problems.
jgaadesh
Post by jgaadesh »
Yes. we have again checked it but issue remains the same.
Also I was Woking on OXE last 7 years so probably I checked all this baby steps before posting this issue
fery_s
Post by fery_s »
i had same problem in release 11.1 and solved when i enter "lanpbxbuild -auto" command.
it seem when update to release 11.1 or 11.2 lanpbx.cfg file need to update.
jgaadesh
Post by jgaadesh »
lanpbxbuild -auto was also tested but issue persist..
jgaadesh
Post by jgaadesh »
Is there any way to upgrade the binary manual with set without call server .looks binary corrupted for sets.
Return to “MAIN”
