VG and GPA2 newbie!!
rojelsilva
Post by rojelsilva »
i have an OXE 4400 with crystal hardware and Appliance CS, the system was migrated and it about it's about 12 years old, we found it migrated.... the telephony version is R9.1-i1.605-29
I have a VG and GPA2 board, all the custumer's voice guides are record over the VG board, i guess.
For the VG card:
(2)coty_gnr> vgstat 1 15
Fri May 13 17:37:06 CEST 2016
etat_vg = VG_STABLE (0)
Slot 1 : Identifier =
Slot 2 : Identifier =
Number of present messages = 45
Message syntax : xxxx = static, xxxx-d = dynamic, xxxx-D = dynamic and static
+------+ Press 'CR' to continue or 'q' to quit +------+
Guide Name Guide MsgLg1 MsgLg2 MsgLg3 MsgLg4 MsgLg5 MsgLg6 MsgLg7 MsgLg8
GPMERAC 3 3
GPNUMCOD 4 4
GPMANAUT 5 5
GPCONUDE 6 6
GPRV 7 7
GPRAPPEL 8 8
GPVONUM 9 9
GPRAPEET 10 10
GPRAPATT 11 11
GPATTRAPEET 12 12
GPEET 13 13
GPNUMAF 14 14
GPHEURDV 15 15
GPATT 16 16
GPINACMOMEN 17 17
GPDONDIST 18 18
FILM_EXT 58 58
PBX_ABS 63 63
TONREVEIL 65 65
FILM_EET 68 68
GUIDAR30 100 100
GPATTEET 101 101
GPMESSYMP 102 102
GPATTRECH 103 103
GPSUFRECH 104 104
GPRACRECH 105 105
GPDISA 106 106
GPANNURAP 107 107
GUIDE_HOTEL 108 108
GUID_ATT 110 110
GPSUFSYMP 139 139
GPMAINT 215 215
GPFAX 216 216
GPUA_GUIDE 217 217
GPUA_KEYCONS 218 218
GPUA_KEYPROG 219 219
GUIDE_OAI_1 220 220
GUIDE_OAI_2 221 221
GUIDE_OAI_3 222 222
GUIDE_OAI_4 223 223
GUIDE_OAI_5 224 224
GUIDE_OAI_6 225 225
TONLEN37 252 252
TONLEN39 254 254
TONLEN40 255 255
Available voice guides channels = 18
Active channel :
for the GPA2 card:
(2)coty_gnr> vgstat 1 21
Fri May 13 17:38:03 CEST 2016
Batteries for backup of voice guides are GOOD
Slot 1 : Card status register = 4E Identifier =
Static voice guides Language : 0 - Not used
Slot 2 : Card status register = 4E Identifier =
Slot 3 : Card status register = 4E Identifier =
Slot 4 : Card status register = 4E Identifier =
Slot 5 : Card status register = 3C
Dynamic voice guides
Total size = 7729472 bytes (1888 pages) (966 sec)
Free size = 7729472 bytes (1888 pages) (966 sec)
Fill ratio = 0.0 %
Available size = 7729472 bytes (1888 pages) (966 sec)
Number of present messages = 0
Dynamic messages configured but not downloaded :
Dynamic messages waiting for download :
Available voice guides channels = 60
Active channel :
My customer wants to record new messages, but if i'm not wrong only is possible if I unplug the VG card, eject the Flash Card and transfer messages with Alcatel audiostation and a Flash Card Reader from my PC, is this correct?
Then, for what is used the GPA2 board? Is possible to transfer all the VG messages to CS or to GPA2? Usually, I used to transfer voice guides to usr7/vg/dhs/ is possible to use it? Or CS?
Sorry for my english.
OXE_4400
Re: VG and GPA2 newbie!!
Post by OXE_4400 »
Its better to forget about new message adding on VG. Too complicated. Check does exist UA RECORDING license. It will allow to record VG from 403x or 803x phone set or transfer WAV file to OXE using Audio station and activate on GPA2
you can add new messages to VG project for GPA2 (if you have AAS and experience).
Allowed to use at the same time VG and GPA2 board. Project (msk file) - you can transfer to /usr7/vg (dhs, flash\std, flash/custom) folder. Depends of file name and VG aim.
Return to “Shelf”
