500 DECT
ludo62
500 DECT
Post by ludo62 »
hello , i want to know how to reset a 500 DECT handset because somebody change the pin code :? and he don 't remenber the code.
thanks
ludo62
Re: 500 DECT
Post by ludo62 »
no one knows key combinaison to reset alcatel M500 ?
KoenC
Re: 500 DECT
Post by KoenC »
These phones are end of life because of poor product quality, the best thing to do is buy a new equivalent (8242 or 8262).
But if your really want to reset the device to factory default, you can do this by the menu or by the procedure below:
1) Press the OK button the access the menu
2) When the menu icons are displayed form the following code (this code will not be displayed on your screen): *632* (or *7378423*)
3) Select EEprom reset
Good luck,
Grts
ludo62
Re: 500 DECT
Post by ludo62 »
thanks for answering . You were right with change M500 for 8262
Return to “DECT”
