CCS calendar empty after performing bascul
jeremy13400
Post by jeremy13400 »
I recently installed CCS v10.4 with R11.1 OXE and I noticed an issue quite annoying : CCS Calendar disappears after bascul.
I can't find any information regarding this so im unsure whether it's simply a bug or I did something wrong...?
Thank you for reading!
sadim
Re: CCS calendar empty after performing bascul
Post by sadim »
What is the OXE version and provide the evxxxxx.log file
Split
Post by Split »
Not sure what you mean with disappears but
I think there was a bug in R11.1 that sometimes the calender entry in CCS was empty ......ALU fix this with a patch
jeremy13400
Can't connect easily at my customer to provide exact OXE release & files but I will try whenever I have the chance to.
I will have a look into patch fixes to see if I can find anything related.
Thank you for helping.
Return to “CCD / CCS / CCIVR”
