Factory Reset 8082 My IC Phone
Telecom_Repair
Post by Telecom_Repair »
Can anyone share the prodedure for factory defaulting a 8082 phone?
I have checked the forum and can see people asking but noone answering
oldboy
Re: Factory Reset 8082 My IC Phone
Post by oldboy »
8082 depending on the version o the phone you can go in when it is 2/5, go into admin and then select factory default
rojeltq
Post by rojeltq »
Login as admin
password : *tx8000#
then you can factory reset, hopefully this helps.
Sent from my SM-G935F using Tapatalk
RojelQ
fe80
Post by fe80 »
Have bricked 8082 MyIc Phone too. Unfortunately the device is unable to start telnetd or sshd anymore. Repeating error line:
dmconfig: curl ret: 35 & http code: 000
Unknown
is the only live tegn. :-/
Maybe someone here knows a secret hardware reset or how to activate a backup bootloader?
cae22
Post by cae22 »
Hello! I have the same problem...
skhany
Post by skhany »
Anyone can help please, I am also trying to reset the phone as it is not accepting the admin default password.
and how to do firmware update?
Thanks.
Return to “Hardware”
