Accounting problem
fery_s
Accounting problem
Post by fery_s »
Hi dear alcatel man
i have oxe with release 11 (k1.400.37) with 2 cpu 7-2 .
my problem is that when the cpua become main the billing application that work with ethernet just work for hours (maximum 1 day) after that in cpua i give incident 2663 with title " IPC Chorus err: appli SERV_APL oper 6 err -11 ". at first i think the problem was from billing application but it works fine with cpub and have no problem .
do you have any idea for this problem????
Re: Accounting problem
Do a:
incinfo GEA 2663
Saturated file system.
Check free space
fery_s
Post by fery_s »
cavagnaro wrote:Do a:
incinfo GEA 2663
Check free space
thank you cavagnaro
thats first thing that i check. no problem from free space.
sadim
Post by sadim »
Check if the real time accounting is set to a V24 port. If not needed disable it, if needed check if it is set to a good serial port
fery_s
Post by fery_s »
sadim wrote:Check if the real time accounting is set to a V24 port. If not needed disable it, if needed check if it is set to a good serial port
hi sadim
the billing application that i use do not work with serial port .
swinstu
Post by swinstu »
Perhaps try master copy from cpu a to cpu b and if still good then rebuild cpu a. Maybe problem with software load on CPU A. Have experienced issues even opentouch builds from the factory with some apps not working correctly and then a rebuild having to fix the issue.
Sent from my SM-N910G using Tapatalk
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
swinstu
Post by swinstu »
I meant do mastercopy from cpu b to cpu a and then check.
SWINSTU
ACSE OXE R12.1
fery_s
Post by fery_s »
swinstu wrote:I meant do mastercopy from cpu b to cpu a and then check.
hi swinstu and thanks for your responding
i installing software and do master copy but this issu not solved.
fery_s
Post by fery_s »
no more advice ??
We also have personal lives, if need urgency open an eSR with ALE
Return to “MAIN”
