Configuration Engine Error
Alcatel Configuration Tool for International Sales -all ACTIS related topics, how-to's, tips and tricks.
Waqas Rehman
Post by Waqas Rehman »
Hi Everyone
Can anyone please help me to rectify the attached error in ACTIS.
This is new for me and i have no idea how to resolve this one
Thank you in advance :)
Cheers
Waqas
Re: Configuration Engine Error
Looks like - cabinet type instead of "calculated" declared like "forced" (declared exactly cabinet type). Actis cannot insert new board (no free space).
Waqas Rehman
Thank you Vad,
there were three cabinets which were forced , i have changed them to calculated mode and forced the system to latest generation rack,
Now the only issue i am having is listed below:
Warning DECT/PWT sets traffic exceeded (sets = 6.20 erlangs, base stations = 6.00 erlangs)
Warning DECT/PWT sets traffic exceeded (sets = 6.00 erlangs, base stations = 3.00 erlangs)
Warning The calculated cabinet for the 2 88 Abbott St peripheral area is different from the forced one
Warning The calculated cabinet for the 3 U7/12-14 Hassell St peripheral area is different from the forced one
Error Board PowerMEX not allowed in rack 45 position 0
any idea please
Hi Waqas,
are you from Al Rostamani? :)
Because I don't know calculated system - I cannot give the good answer why you have problem with rack 45.
Check, may be you have some problem with initial OPS files. Just try to make add-on for initial file (grey) and add nothing (just add-on/configuration) - do you have some error?
If no - try to make add-on "step-by-step" - on which stage you will have error.
If you have problem with initial file without add some requirements:
- check hardware.mao file, when used OPS files from PBX - sometimes hardware.mao file not good (just extract hardware.mao and *.hw from *.zip file)
- try "patch before add-on" - if you have some problem with hardware - you can manually change shelf type/ board type or position before add-on
Best regards, Vadim (Perm, Russia)
Waqas Rehman
Hi Vadim,
Yes i was in Al Rostamani :-)
Now working in Australia from last 8 months
Thank you for the reply let me check this and see if i can sort out the issue :-)
Thank you for your support
Cheers
Waqas
Return to “Actis”
