OTMS 2.2- FlexLM problem
Vladislav
Post by Vladislav »
Dear all,
I have a problem, concerning licensing of OTMS (License server is not available).
Both servers (FlexLM + OTMS) have same *.ice file (as required for OTID definition).
Some tests which i made said OK. You can find screenshots in Attachments.
Moreover, everything is working fine with OXE interaction (used same FlexLM server).
A lot of restarts (oxe/otms/flexlm) was made.
What is the reason of this fault?
May be something wrong with port 2700?
Help me, please!!
Happy New Year!!!
mgoegel
Re: OTMS 2.2- FlexLM problem
Post by mgoegel »
This may not help you anymore (after almost 6 month)...
But maybe someone other (or me in the future). ;-)
I currently hanging around with an OTMS installation and had some issues with this too on latest 2.2.1.
Somehow, when I switched to the second FlexLM server, it got it up and running. But the today I checked everything again via the new Maintenance Portal and got a hint, there there is still something wrong: I had to remove all the .lic or .otm* files from /var/data/licenses and restart the server.
After that licensing was still fine and this time without any hints/issues from license check.
Regards Mario
Return to “OTMS - OpenTouch Multimedia Services”
